Home » Language IDEs » C / C++ IDE (CDT) » Problems compiling C sources
Problems compiling C sources [message #209592] Mon, 11 February 2008 03:42
Originally posted by: xxx.yyy.zz
Hi all,
Eclipse 3.3.0
In these days i receive some errors i had never received.
Launching the build of the project i see:
- gcc (cc1.exe) crashes wih an exception error: the memory cannot be
'written'
- the console window reports:
make all
Building file: ../bmpCatobo80.c
Invoking: GCC C Compiler
C:\Programmi\WinAVR-20070525\bin\avr-gcc.exe -I"J:\Progetti\Software\Catobo\
401007\src\SolarPlus" -I"J:\Progetti\Software\Catobo\401007\src\SolarPlus\in
clude" -I"J:\Progetti\Software\Catobo\401007\src\SolarPlus\system" -I"C:\Pro
grammi\WinAVR-20070525\avr\include\avr" -O0 -g -Wall -c -fmessage-length=0 -
gdwarf-2 -std=gnu99 -mmcu=atmega128 -DF_CPU=16000000UL -funsigned-char -funs
igned-bitfields -MMD -MP -MF"bmpCatobo80.d" -MT"bmpCatobo80.d" -o"bmpCatobo8
0.o" "../bmpCatobo80.c"
/bin/sh: -c: line 3: syntax error: unexpected end of file
make: *** [bmpCatobo80.o] Error 258
If I cut&paste and run the above command on a 'dos window' everything goes
witout errors!!
- the log generated by Eclipse reports:
!SESSION 2008-02-11
09:25:08.418 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.version=1.6.0_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Command-line arguments: -os win32 -ws win32 -arch x86
This is a continuation of log file
J:\Progetti\Software\Catobo\401007\src\.metadata\.bak_0.log
Created Time: 2008-02-11 09:31:16.058
!ENTRY org.eclipse.ui 4 4 2008-02-11 09:31:16.074
!MESSAGE The proxied handler for
'org.eclipse.team.internal.ccvs.ui.actions.CompareWithTagAct ion' could not
be loaded
!ENTRY org.eclipse.ui 4 0 2008-02-11 09:31:16.074
be loaded
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.team.cvs.ui"
was unable to instantiate class
" org.eclipse.team.internal.ccvs.ui.actions.CompareWithTagActi on ".
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(
RegistryStrategyOSGI.java:180)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutabl
eExtension(RegistryStrategyOSGI.java:174)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtensi
on(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExte
nsion(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutab
leExtension(ConfigurationElementHandle.java:51)
... at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
org.eclipse.core.runtime.CoreException[1]: java.lang.NoClassDefFoundError:
org/eclipse/team/internal/core/subscribers/SubscriberDiffTre eEventHandler$ID
iffFilterProvider
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(Default
ClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathMa
nager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(Classpath
Manager.java:471)
.... at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2008-02-11 09:31:16.074
!MESSAGE Plug-in "org.eclipse.team.cvs.ui" was unable to instantiate class
!STACK 0
iffFilterProvider
nager.java:501)
Manager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(Clas
spathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(Classpat
hManager.java:413)
.... at java.lang.reflect.Method.invoke(Unknown Source)
!ENTRY org.eclipse.ui 4 4 2008-02-11 09:31:16.089
be loaded
!ENTRY org.eclipse.ui 4 0 2008-02-11 09:31:16.105
be loaded
!STACK 1
org.eclipse.ui.internal.handlers.LegacyHandlerProxy.loadHand ler(LegacyHandle
rProxy.java:116)
.... at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
iffFilterProvider
nager.java:501)
Manager.java:471)
hManager.java:413)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(Defa
ultClassLoader.java:189)
.... at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2008-02-11 09:31:16.105
!STACK 0
iffFilterProvider
nager.java:501)
Manager.java:471)
hManager.java:413)
If I check the updates, the tool lists some 3.2 patches! Is it correct
???Thanks !
SteM
Previous Topic:CDT not playing nice with GLUT
Next Topic:gdb debugger issue
Current Time: Tue Jul 22 14:47:36 EDT 2025
Powered by FUDForum. Page generated in 0.04138 seconds
