Home » Eclipse Projects » Subversive » Newby: Linux Connector
Newby: Linux Connector [message #20248] Mon, 09 June 2008 04:18 Go to next message
Hi there,
I used Subclipse before but want to try Subversive now. I understand at
Subversive you need some kind of low level connectors which are
proprietory and not shipped with Eclipse, right? I require a connector
for Linux-32. Where can I get one?
Hauke
Re: Newby: Linux Connector [message #20642 is a reply to message #20248] Mon, 09 June 2008 12:42 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Hauke,
All required connectors are distributed from the following update site:
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/
The only one moment related to Linux and Mac users is that we suppose
native binaries already installed on the client machine (including
binaries for JavaHL library).
Re: Newby: Linux Connector [message #20680 is a reply to message #20642] Tue, 10 June 2008 02:43 Go to previous messageGo to next message
Thanks for the answer. On stable debian we have only subversion 1.4.2.
Is the JavaHL 1.4.5 compatible to that?
Hauke
Re: Newby: Linux Connector [message #20694 is a reply to message #20680] Tue, 10 June 2008 05:19 Go to previous message
AFAIR, JavaHL 1.4.5 does not contain any API changes in compare to JavaHL
1.4.2. So, these versions are compatible and you can use 1.4.2 version
instead of 1.4.5.
Previous Topic:How to attach Subversive to an externally checked out working copy?
Next Topic:Does svn+ssh work with the Subversive SVN Connector and SVNKit 1.1.7?
Current Time: Mon Jul 07 13:03:01 EDT 2025
Powered by FUDForum. Page generated in 0.04330 seconds
