Home » Archived » BIRT » Images not displaying
Images not displaying [message #209424] Fri, 05 January 2007 10:48 Go to next message
Originally posted by: elgoodm.sandia.gov
Images in my report that are referenced via URI's display fine when I test
the report within eclipse, but do not display when I use the
WebViewerExample to display the report on an application server.
In the log I am getting messages like the following:
Jan 5, 2007 8:26:01 AM
org.eclipse.birt.report.engine.api.HTMLServerImageHandler handleImage
SEVERE: imageURL or ImageDIR is not set!
Here are some details on my setup:
BIRT Viewer Version: 2.1.0
BIRT Engine Version: 2.1.0
Application Server: Weblogic 9.2
For the image URI's, I use relative paths, e.g.
if (!params["Asset Subtype"].match("DATA SUBJECT AREA PATTERN"))
"../images/moreGeneral.bmp";
else
"../images/blank.bmp";
Within the WAR, all of my images are stored in WebRoot/images/ and the
report is stored in WebRoot/prod/, so the relative path should be correct.
To display the report, I use the URL:
<server location>/WebViewerExample/run?__report=prod/data.rptdesign
In the generated HTML, displaying the report with eclipse I get image tags
like the following:
<img id="AUTOGENBOOKMARK_24" src="/viewer/run?__imageID=file560.bmp"
alt="">
However, the generated HTML with the application server has
<img id="AUTOGENBOOKMARK_24" alt="">
Any ideas?
Eric
Re: Images not displaying [message #209497 is a reply to message #209424] Fri, 05 January 2007 14:17 Go to previous messageGo to next message
Originally posted by: home4slc.pacbell.net
Hi Eric,
I have been experiencing a similar, if not exactly the same, problem for
quite some time now. See these two posts:
http://dev.eclipse.org/newslists/news.eclipse.birt/msg15116. html
http://dev.eclipse.org/newslists/news.eclipse.birt/msg15468. html
For the last one I believe I've been told to log a bug. I'll do so
later today and reference all three of these posts. Once I've logged
the bug I'll add another response to this post with the bug number.
Susan
> test the report within eclipse, but do not display when I use the
> else
> tags like the following:
> alt="">
> Any ideas?
> Eric
Re: Images not displaying [message #209543 is a reply to message #209497] Fri, 05 January 2007 17:11 Go to previous messageGo to next message
Susan,
Thanks for the info.
A little more information: I tried deploying my report and the viewer on
Tomcat 5.5.20 and the report displays fine. So it appears to be a
compatibility problem with Weblogic.
Eric
Re: Images not displaying [message #209847 is a reply to message #209543] Mon, 08 January 2007 13:29 Go to previous message
Hi Eric,
I filed a bug today about charts not appearing in the web viewer app on
WebSphere 5.1
https://bugs.eclipse.org/bugs/show_bug.cgi?id=169873
I too can get my charts to appear on Tomcat 5.5.x. The charts also
appear in WebSphere 6.0.
You might want to update the bug with the info about it not working on
WebLogid either.
Susan
Eric wrote:
> Susan,
> Eric
Previous Topic:Several Questions about using cusotm BIRT lib
Next Topic:Chart Size By URL Parameter
Current Time: Mon Jul 14 09:09:01 EDT 2025
Powered by FUDForum. Page generated in 0.05870 seconds
