Home » Eclipse Projects » Subversive » subversive asks 100 times a day for password
subversive asks 100 times a day for password [message #20225] Sat, 07 June 2008 00:41 Go to next message
Originally posted by: erik.putrycz.remove-nrc-cnrc.gc.ca
For some reason I cannot figure out, Subversive with SVN Kit 1.2.0 keeps
asking for password at least 10 times for browsing any repository. I have
the option checked to remember the password but the dialog keeps coming
and I have to press "Ok" every time. Any suggestions?
Re: subversive asks 100 times a day for password [message #20236 is a reply to message #20225] Sat, 07 June 2008 13:30 Go to previous messageGo to next message
> have the option checked to remember the password but the dialog keeps
> coming and I have to press "Ok" every time. Any suggestions?
I remember this problem from using Subversive while still a Polarion
only project about 2 years ago.
In our case, this was related to using a proxy at a large customer.
Are you behind a proxy or firewall?
Re: subversive asks 100 times a day for password [message #20240 is a reply to message #20236] Sun, 08 June 2008 13:56 Go to previous messageGo to next message
Not at all... In which file are the password stored? Even unchecking the
password box for "remember" doesn't seem to do anything. Also it looks
like this issue occurred last time I did a major version upgrade of
subversive.
Erik.
Re: subversive asks 100 times a day for password [message #20254 is a reply to message #20240] Mon, 09 June 2008 12:28 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Erik,
I tried to reproduce described problem, but I can't. Could you please
provide some steps to reproduce and additional information?
1) Is it the latest Subversive build or not?
2) Which protocol you use (http, https, svn or svn+ssh)?
3) Repository URL (only if it is public and accessible through Internet)?
P.S.
Latest Subversive version uses Eclipse Platform services for storing
secure information.
Re: subversive asks 100 times a day for password [message #20706 is a reply to message #20254] Tue, 10 June 2008 11:54 Go to previous messageGo to next message
Alexander Gurov wrote:
> Hello Erik,
> P.S.
> secure information.
Do you know if the Eclipse Platform services part of the base Eclipse
3.3.2? I am running the Eclipse Classic 3.3.2 and I am encountering
problems with logging a subersion repository using svn+ssh. I am using
svnKit 1.1.7. I think my problem originates from svnkit.
Re: subversive asks 100 times a day for password [message #21318 is a reply to message #20225] Thu, 12 June 2008 18:47 Go to previous messageGo to next message
I was also having this problem. Today I found a way around it. Check
https://bugs.eclipse.org/bugs/show_bug.cgi?id=221094
There is not that much information, but thing is I just changed a
DEFAULT_ID from 'svnkit' to 'svnkit15' and it worked.
In order to do this you have to get subversive sources and, after making
the modification above, build the plugin into something like
org.eclipse.team.svn.core_0.7.1.I20080612-1500.jar. Then copy it to
eclipse/plugins directory and restart eclipse.
Note that, afterwards, while svnkit 1.2.0 connector will work, svnkit
1.1.7 connector will show this exact same problem.
Re: subversive asks 100 times a day for password [message #21387 is a reply to message #21318] Sat, 14 June 2008 05:20 Go to previous messageGo to next message
Hello Fabio,
You also can try to switch connectors without changing and recompiling the
Subversive code. In order to do this please use optiona at
Window->Preferences->Team->SVN->SVN Connector.
Re: subversive asks 100 times a day for password [message #21395 is a reply to message #21387] Mon, 16 June 2008 08:50 Go to previous messageGo to next message
Thanks, Alexander, but I already had my working copy converted to svn 1.5,
so I think I have to use svnkit's development version. Right?
Re: subversive asks 100 times a day for password [message #21401 is a reply to message #21395] Mon, 16 June 2008 15:53 Go to previous message
Yes, you are right. Its name in plug-in preferences is SVN Kit 1.2.0
development.
Previous Topic:pure Java connector
Next Topic:"Share project" not available
Current Time: Tue Jul 15 13:29:41 EDT 2025
Powered by FUDForum. Page generated in 0.30024 seconds
