Home » Language IDEs » ServerTools (WTP) » Re: J2EE runtime directory
Re: J2EE runtime directory [message #209003] Sat, 23 February 2008 07:32 Go to next message
Wen,
It's best to use the WTP newsgroup. I've added it to the "to" list of
this reply. I wonder if it's just the"jre" folder nested within the
JDK? I know nothing about this though...
Wen He wrote:
> Hi:
> I am doing the tutorial to create a web project and get stuck on "J2EE
> runtime directory", anyone know where exactly it is? (I have installed
> the lastest JDK with EE)
> LINK TO THE TUTORIAL:
> http://www.eclipse.org/webtools/jst/components/j2ee/scenario s/webprojectcreation_tutorial.html
> THIS IS THE STATEMENT I GET STUCK ON:
> "Click Browse... button for Location, and point to your J2EE runtime
> directory in your file system, and click Finish. "
> Thank you very much
> Wen
Re: J2EE runtime directory [message #209011 is a reply to message #209003] Sat, 23 February 2008 10:25 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Yes, this is a place where you have the J2EE JDK installed if you are
using the generic runtime as shown in the tutorial. From my
understanding this is only used if you just want to do compilations and
don't want to do debugging or testing.
Dave
Ed Merks wrote:
> Wen,
> Wen He wrote:
>> Hi:
>> Thank you very much
>> Wen
Re: J2EE runtime directory [message #209019 is a reply to message #209011] Sun, 24 February 2008 03:43 Go to previous messageGo to next message
> Dave
Hi Dave:
Thank you for the answer.
But where should I go if I want to do debugging or testing?
Thank you again.
Wen
Re: J2EE runtime directory [message #209027 is a reply to message #209003] Sun, 24 February 2008 03:45 Go to previous messageGo to next message
Ed Merks wrote:
> Wen,
> this reply.
Hi Ed:
Thank you very much for telling me about the WTP group. It reminded me
that I was not a brand new comer anymore. :)
Wen
Re: J2EE runtime directory [message #209042 is a reply to message #209019] Sun, 24 February 2008 10:18 Go to previous messageGo to next message
Your best bet if you want to do debugging or testing, is to install one
of the supported Server Runtimes (i.e. Tomcat, Jetty, JBOSS, etc).
This will allow you to associate a project with a particular server
runtime, and allow you to do debugging and testing.
Dave
>> and don't want to do debugging or testing.
>> Dave
> Hi Dave:
> Thank you for the answer. But where should I go if I want to do
> Thank you again.
> Wen
Re: J2EE runtime directory [message #209089 is a reply to message #209042] Mon, 25 February 2008 14:01 Go to previous message
Originally posted by: "jesse,mcconnell".gmail.com
I'll ask here since its related to Server Runtimes...
I noticed that the tomcat plugin (the one in the wtp source) has a lot
of custom code in it not strictly making use of the jst and wst
extension points for things like deploying the webapp, etc. Looked like
it was to enable deploying the webapp to a tomcat installation without
having to package it up as a war and deploy that bundle...
is there a recommended mechanic for toggling this kind of behavior on
and off where I can make use of the existing jetty wtp integration that
deploys the bundle and then just enable some special mode that will
generate the configuration required to use an war exploded someplace
else like in the project?
jesse
> of the supported Server Runtimes (i.e. Tomcat, Jetty, JBOSS, etc). This
> will allow you to associate a project with a particular server runtime,
> Dave
>>> Dave
>> Hi Dave:
>> Thank you again.
>> Wen
Previous Topic:"document" unresolved for javascript files
Next Topic:Re: Tomcat fails to start
Current Time: Fri Jul 18 00:05:41 EDT 2025
Powered by FUDForum. Page generated in 0.08087 seconds
