Home » Archived » Visual Editor (VE) » VE 1.0 Plans
VE 1.0 Plans [message #20196] Fri, 20 February 2004 02:42 Go to next message
Is there a plan document for the 1.0 version of VE?
Francesc Rosés
Re: VE 1.0 Plans [message #20212 is a reply to message #20196] Fri, 20 February 2004 10:37 Go to previous messageGo to next message
The Visual Editor's 1.0.0 Line Item Objectives (i.e. plan) is available
here:
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /vep-home/WebContent/docs/v1.0.0/line-items/index.htm
- Jeff
Francesc Rosés wrote:
> Hello,
> Francesc Rosés
Re: VE 1.0 Plans [message #20235 is a reply to message #20212] Sat, 21 February 2004 11:12 Go to previous messageGo to next message
I observe the major efforts are in the SWT area. We can't
expect enhancements in the tool behavior nor the Swing support?
For example, the word "performance" don't appears, but I observed
better performance in the 1.0 integration builds...
Francesc
> here:
> - Jeff
> > Hello,
> > Francesc Rosés
Re: VE 1.0 Plans [message #20668 is a reply to message #20235] Tue, 24 February 2004 09:05 Go to previous messageGo to next message
> Hello,
> Francesc
>>here:
>> - Jeff
>>>Hello,
>>> Francesc Rosés
There are three major goals for v1.0.0:
1. Start with SWT support (as noted above)
2. Improve performance.
o Reduce code path
o Reduce the need for a reload from scratch
o Perform most of the bottom up updates in the background.
We have made some advances on the 1st bullet, but have much to go on.
We have not started on the last two bullets.
3. v3 Eclipse
Re: VE 1.0 Plans [message #21325 is a reply to message #20668] Fri, 27 February 2004 03:20 Go to previous messageGo to next message
How about better support for GridBagLayouts?
For me and my thousands of dialogs/panels, this is by far the most-used
Layout. In VisualAge you drag components within the layout to put them into
different cells. This does not seem to work in VE. Actually it makes working
with VE quite painful. Any plans on that?
Cheers and thanks for the good work
Andy
"Gili Mendel" <mendelgili@netscape.net> schrieb im Newsbeitrag
news:c1flgt$8gk$1@eclipse.org...
> Francesc Ros
Re: VE 1.0 Plans [message #21346 is a reply to message #21325] Fri, 27 February 2004 09:29 Go to previous messageGo to next message
I'd recommend reading my article "Effective Layout Management" to avoid
using BarfBag. You can get a much cleaner/maintainable design this
way...
See
http://developer.java.sun.com/developer/onlineTraining/GUI/A WTLayoutMgr
Note that when I wrote it BoxLayout didn't exist. The parts of the
example that use BarfBag can be very easily done with a nested BoxLayout
(off the top of my head):
Panel [BoxLayout(X_AXIS)]
h-strut
FileDisplay
h-strut
Panel [BoxLayout(Y_AXIS)]
v-glue
Button("-->")
v-strut
Button("<--")
v-glue
h-strut
FileDisplay
h-strut
That simple design replaces a 6-component BarfBag, which requires 66
constraint settings...
I gave a talk at JavaOne based on the article, and you can get the
slides at
http://www.javadude.com/articles/javaone/Effective%20Layout%
20Management.zip
These slides talk about the BoxLayout design a bit.
SpringLayout may make things even easier, though I haven't played with
it yet.
If you're using BoxLayout, take a look at my BoxBeans, which can be used
in visual builder tools to help adjust components to stretch/shrink
appropriately. (http://javadude.com/tools). I haven't tried them in VE,
though, but they should work.
Of course I wouldn't recommend wholesale redesign for all of your
existing screens, but you could slowly rework them to reduce your
dependency on BarfBag.
Later,
-- Scott
In article <c1muem$eh3$1@eclipse.org>, andreas.wuertz@information-
factory.com says...
Re: VE 1.0 Plans [message #21354 is a reply to message #21346] Fri, 27 February 2004 09:54 Go to previous messageGo to next message
Thanks for the info, but it doesn't really help me, because:
- I have over 1000 dialogs/panels that I cannot/do not want to completely
redesign, but have to maintain from time to time (i.e once every year)
- I am not sure if nesting panels just for layout purposes should be the way
to go (of course, sometimes it is inevitable)
- BoxLayouts do not exist in Java1, but we are still supporting MacOS 9
- I really love GridBagLayouts - under VisualAge, they are quite easy to use
Cheers
Andy
"Scott Stanchfield" <scott@javadude.com> schrieb im Newsbeitrag
news:MPG.1aa91e70637e134298969f@news.eclipse.org...
> way...
> See
> h-strut
> FileDisplay
> h-strut
> v-glue
> Button("-->")
> v-strut
> Button("<--")
> v-glue
> h-strut
> FileDisplay
> h-strut
> slides at
> 20Management.zip
> it yet.
> Later,
> -- Scott
> factory.com says...
into
working
Re: VE 1.0 Plans [message #21386 is a reply to message #21354] Fri, 27 February 2004 16:40 Go to previous messageGo to next message
That's cool. Just keep these ideas in mind when designing new screens or
making significant changes to old screens. Much simpler.
Of course eventually VE will have better BarfBag support, as will
Penumbra when I release it (don't ask when -- don't know yet).
Later,
-- Scott
In article <c1nlg6$ejh$1@eclipse.org>, andreas.wuertz@information-
factory.com says...
> Cheers
> Andy
> > using BarfBag. [...]
Re: VE 1.0 Plans [message #21497 is a reply to message #21325] Mon, 01 March 2004 09:34 Go to previous messageGo to next message
> Andy
Visual support for GridBag is available in the Visual Editor for Java
(in the WebSphere Studio products) and was not moved to VE because of
pending patents in this area.
As time go by, I would hope to see such basic necessities move into open
source.
Re: VE 1.0 Plans [message #21797 is a reply to message #21497] Wed, 03 March 2004 07:27 Go to previous messageGo to next message
Thanks for the info.
Does that mean it is going to take ages for the visual support to be
integrated? Or are they already in the process of solving those patent
problems?
Cheers
Andy
news:c1vhf1$4ij$1@eclipse.org...
> Andreas W
Re: VE 1.0 Plans [message #21933 is a reply to message #21797] Wed, 03 March 2004 09:04 Go to previous messageGo to next message
> problems?
> Cheers
> Andy
I wish I could give you a direct answer, but I can not. ... every
problem can be viewed as in the process of getting solved ;-). The
problem is that in most cases it is impossible to determine with
certainty how long will that process take.
Re: VE 1.0 Plans [message #22240 is a reply to message #21933] Wed, 03 March 2004 19:48 Go to previous messageGo to next message
Originally posted by: frans.intercitra.com
Anyone know the status of VE 1.0, it is a Swing only or will release
after the SWT designer finish?
>> problems?
>> Cheers
>> Andy
Re: VE 1.0 Plans [message #22485 is a reply to message #22240] Thu, 04 March 2004 09:12 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
SWT is being worked on at this time. It will be available when 1.0.0 if
finally released. The current integration driver has some small support
(can only drop a shell, but there are problems with it).
Thanks, Rich Kulp
Create SWT Re: VE 1.0 Plans [message #23257 is a reply to message #22485] Sat, 06 March 2004 06:44 Go to previous messageGo to next message
I added swt library to a project that have vep 1.0, and when I create
new visual class, I cannot create a swt form, but Swing form
can you help>?
Re: Create SWT Re: VE 1.0 Plans [message #23260 is a reply to message #23257] Sat, 06 March 2004 10:21 Go to previous messageGo to next message
Originally posted by: jdm0532.nospam.cs.rit.edu
The Visual Class Wizard hasn't been changed yet to create an SWT class.
Simply choose to extend Object from the Visual Class Wizard, and the
SWT palette will show up if you have the SWT library included in the
project.
- Jeff
> can you help>?
>> if finally released. The current integration driver has some small
>> support (can only drop a shell, but there are problems with it).
Re: Create SWT Re: VE 1.0 Plans [message #23267 is a reply to message #23260] Sat, 06 March 2004 10:30 Go to previous message
Right now you have to include "SWT Container" from the java build page
Add library button. That is the only way we currently recognize SWT.
Just adding SWT.jar to the build path doesn't work for VE.
Thanks, Rich Kulp
Re: VE 1.0 Plans [message #582023 is a reply to message #20196] Fri, 20 February 2004 10:37 Go to previous message
here:
- Jeff
> Hello,
> Francesc Rosés
Re: VE 1.0 Plans [message #582175 is a reply to message #20212] Sat, 21 February 2004 11:12 Go to previous message
Francesc
> here:
> - Jeff
> > Hello,
> > Francesc Rosés
Re: VE 1.0 Plans [message #582335 is a reply to message #20235] Tue, 24 February 2004 09:05 Go to previous message
> Hello,
> Francesc
>>here:
>> - Jeff
>>>Hello,
>>> Francesc Rosés
o Reduce code path
3. v3 Eclipse
Re: VE 1.0 Plans [message #582634 is a reply to message #20668] Fri, 27 February 2004 03:20 Go to previous message
Andy
> Francesc Ros
Re: VE 1.0 Plans [message #582679 is a reply to message #21325] Fri, 27 February 2004 09:29 Go to previous message
way...
See
h-strut
FileDisplay
h-strut
v-glue
Button("-->")
v-strut
Button("<--")
v-glue
h-strut
FileDisplay
h-strut
slides at
20Management.zip
it yet.
Later,
-- Scott
factory.com says...
Re: VE 1.0 Plans [message #582696 is a reply to message #21346] Fri, 27 February 2004 09:54 Go to previous message
Cheers
Andy
> way...
> See
> h-strut
> FileDisplay
> h-strut
> v-glue
> Button("-->")
> v-strut
> Button("<--")
> v-glue
> h-strut
> FileDisplay
> h-strut
> slides at
> 20Management.zip
> it yet.
> Later,
> -- Scott
> factory.com says...
into
working
Re: VE 1.0 Plans [message #582752 is a reply to message #21354] Fri, 27 February 2004 16:40 Go to previous message
Later,
-- Scott
factory.com says...
> Cheers
> Andy
Re: VE 1.0 Plans [message #582938 is a reply to message #21325] Mon, 01 March 2004 09:34 Go to previous message
> Andy
source.
Re: VE 1.0 Plans [message #583077 is a reply to message #21497] Wed, 03 March 2004 07:27 Go to previous message
problems?
Cheers
Andy
> Andreas W
Re: VE 1.0 Plans [message #583128 is a reply to message #21797] Wed, 03 March 2004 09:04 Go to previous message
> problems?
> Cheers
> Andy
Re: VE 1.0 Plans [message #583262 is a reply to message #21933] Wed, 03 March 2004 19:48 Go to previous message
>> problems?
>> Cheers
>> Andy
Re: VE 1.0 Plans [message #583321 is a reply to message #22240] Thu, 04 March 2004 09:12 Go to previous message
Thanks, Rich Kulp
Create SWT Re: VE 1.0 Plans [message #583630 is a reply to message #22485] Sat, 06 March 2004 06:44 Go to previous message
can you help>?
Re: Create SWT Re: VE 1.0 Plans [message #583646 is a reply to message #23257] Sat, 06 March 2004 10:21 Go to previous message
project.
- Jeff
> can you help>?
Re: Create SWT Re: VE 1.0 Plans [message #583659 is a reply to message #23260] Sat, 06 March 2004 10:30 Go to previous message
Thanks, Rich Kulp
Previous Topic:Support for actions in GUI builder?
Next Topic:i can't use VE
Current Time: Tue May 13 14:53:55 EDT 2025
Powered by FUDForum. Page generated in 0.07912 seconds
