Home » Archived » Java WorkFlow Tooling (JWT) » move to STP
move to STP [message #20115] |
Fri, 03 February 2006 09:15  |
Originally posted by: fabrice.dewasmes.openwide.fr
Hi all,
Following discussions with STP PMC, it appears that we've got three
options for project creation :
- first we have an opportunity to be incubated as part of the STP BPMN
subproject.
- second we can be incubated inside technology project as every other
project and wait to move to a TLP.
- third start being incubated by technology project and move to STP at a
later time.
What are the consequences of the various options ?
In option 2, we are independant from anyone. But this state is expected
to be temporary as we should move to a TLP anyway.
In option 1, we are still 'somehow' independant from the TLP but in
software group that is clearly our concern.
In option 3, we start by being independant and keep the choice to move
to STP at a later time. HOWEVER, if this will be possible only if no
overlapping project exist inside STP at that time.
I *strongly* invite you to take a look at STP proposal at
http://www.eclipse.org/proposals/stp/
and eventually look at STP web site (even if it is really ready yet) at
http://www.eclipse.org/stp/.
Please keep in mind that process/workflow modeling is typically part of
the tools used to achieve SOA and moving to STP could be wise choice.
I wanted to know what you guys think of this and how we should request
the creation review. Anyone listed in the current JWT proposal state is
called to vote so please do so.
Fabrice Dewasmes
Re: move to STP [message #21504 is a reply to message #20115] |
Fri, 03 February 2006 11:47   |
Originally posted by: rzulauf.objeng.ch
Hi Fabrice
Fabrice Dewasmes wrote:
> Hi all,
> subproject.
> later time.
I feel this is a very important decision. The problem I see is that we
wanted to focus on XPDL while STP has the immediate goal of creating and
using BPEL processes.
In my opinion it would be best to get STP to use our editor and
contribute to it if it is missing support for some stuff they need. The
point is that our mission in terms of workflow editor and tooling is a
bit broader than that of STP - I consider WAM for example misplaced in
STP, and they do not have any need for XPDL or differeng graphical
representations.
Therefore my vote is for option 2, if the STP project agrees on using
our editor. If no consensus can be found, then we will be forced into
option 1 as STP clearly has more support from commercial companies at
the moment and I do not think two BPML editors will eventually survive.
However I do not think it is important as to whether we are considered a
subproject of STP or if we are a TLP, as long as:
- we still have somewhat control over our roadmap
- there is no risk of *two* BPML editors being written
Roman
> Best regards,
> Fabrice Dewasmes
interoperability is not webservices [message #21571 is a reply to message #21522] |
Sun, 05 February 2006 09:13   |
Originally posted by: vgv8.yahoo.com.br
The problem is that webservices in Java platform is synonym of
interoperability and this is wrong policy and distorted concept, if to speak
about general purpose Workflow Designer.
http://elearning4guruscom.ntitemp.com/only4gurus/techlib/mis cellaneous/j2ee_vs_net.pdf
"J2EE vs. NET - An Executive Look"
"Sun's interoperability strategy for J2EE is based on the communications
protocol called IIOP which have the following problems: Only supports J2EE
and CORBA, is not designed to transport over the Internet and current
specification of IIOP is inadequate to ensure interoperability[16].
The.NET platform has a much stronger technology neutral e-Collaboration
strategy than does J2EE.
Inaddition, the .NET platform have a set of application servers that
supports other forms of e-Collaboration..."
Guennadi Vanine
"Guennadi Vanine" <vgv8@yahoo.com.br> wrote in message
news:ds0nn8$sr7$1@utils.eclipse.org...
> I also want XPDL and/or even non-standard (pluggable) XML.
> XPDL is just superset of BPEL, BPML, etc.
> BPEL is linked to WSDL
> But :
> - SOA is NOT synonym of webservices;
> - workflow designers are needed NOT only to specify webservices and SOA!
> They are needed first of all for business processes with user interaction
> what BPEL lacks!
> - webservices is not the means of interoperability in intranet and
> webservices make sense for external to enterprise comm. This is specific
> problem of Java that Java doesn't have interoperable binary protocols
> Well, all this is serious and we should discriminate what doesn't overlap
> with others. If GMF (after pushing EMF) satisfies its requirements of
> extensibility, interoperability, pluggability and support of different
> languages... JWT designer may also be seen as GMF subproject and GMF will
> make many parts of STP redundant also
> I feel bad about all this scattering and multiplication of centrifugal
> projects, framewroks without observable intentions to create integrating
> them architecture
> Less of all, I want to see JWT designer restricted by webservices/BPEL
> Guennadi Vanine
dependencies to take into account [message #21796 is a reply to message #21661] |
Sat, 11 February 2006 16:24   |
I beleive the following thread is relevant to this decision
http://www.eclipse.org/newsportal/article.php?id=1111&gr oup=eclipse.technology.gmf#1111
i.e. there are extensibility, interoperability (both inside and outside of
Eclipse, as well as integration), (re)unification/cooperation (with other
Eclipse projects), XML formats pluggability depending on...
Guennadi Vanine
"Fabrice Dewasmes" <fabrice.dewasmes@openwide.fr> wrote in message
news:dsa8kc$a3u$1@utils.eclipse.org...
>> But :
> beware that WSDL does not necessarily mean web service. More and more WSDL
> is used as a interoperable contract. Kind of interface in the java
> programming language but understable and usable by any language.
> This is true. But what should be taken into consideration is the
> visibility. If we get more visibility being incubated by STP then it may
> be acceptable to switch to STP even if get a 'SOA label'. Of course this
> depends of a shared agreement.
>> what BPEL lacks!
> I guess this won't ever happen. GMF won't host subproject.
>> them architecture
>> Less of all, I (don't ?) want to see JWT designer restricted by
>> webservices/BPEL
> neither do I.
>> Guennadi Vanine
Re: repository is not registry [message #22025 is a reply to message #21751] |
Mon, 13 February 2006 04:50  |
> I saw that repository is sometimes considered to be synonym of registry.
> I do not. IMHO registry (UDDI, WSDL) is usually for services and repository
> IMHO for data, files.
Completely agree.
Current Time: Mon Jun 02 17:59:54 EDT 2025
Powered by FUDForum. Page generated in 0.45877 seconds
