Creating a project within an existing directory [message #208156] |
Mon, 30 April 2007 14:46 |
Originally posted by: dgront.chem.uw.edu.pl
Hello!
I have the main directory called trunk. In trunk I have several
directories with my classes. There are no *.class files directories - only
subdirectories.
So the situation looks like that:
/trunk
|- dir1
| dir1A
| MyClass.java
|- dir2
MyClass2.java
The class MyClass is properly imported as dir1.dir1A.MyClass. For example
file MyClass2.java starts as follows:
import dir1.dir1A.MyClass1;
My CLASSPATH (also the list of jar files defined in Eclipse) points to a
file dir1.jar, that contains a MyClass. The whole package compiles nicely
both with
make and ant.
Now I want to substitute vi with Eclipse. I created a new project called
"trunk" and imported my whole structure into it. And there my problems
starts. Eclipse wants me to change my "import" line from:
to:
import dir1A.MyClass1;
It looks like my package dir1 is not recognized by Eclipse as a package
but as a src-directory with a package "dir1A" inside.
How can I switch of this stupid Windows-like behavior?
I wants my *.class files to be put in:
classes/dir1
and
classes/dir2
respectively, depending on a source directory. Than I want a jar file to
be created from classes/dir1.
I dont't know why eclipse cannot compile my source since dir1.jar file is
already on CLASSPATH and it is also included in "external jars list" in my
project
I hope anyone can help me.
Dominik
Re: Creating a project within an existing directory [message #208165 is a reply to message #208156] |
Mon, 30 April 2007 15:13 |
Dominik,
Bring up the Properties for the project using the popup, select Java
Build Path, and use the Source tab to specify your desired source folders.
dgront wrote:
> Hello!
> only subdirectories.
> /trunk
> |- dir1
> | dir1A
> | MyClass.java
> |- dir2
> MyClass2.java
> example file MyClass2.java starts as follows:
> a file dir1.jar, that contains a MyClass. The whole package compiles
> nicely both with
> make and ant.
> called "trunk" and imported my whole structure into it. And there my
> problems starts. Eclipse wants me to change my "import" line from:
> to:
> package but as a src-directory with a package "dir1A" inside.
> classes/dir1
> and
> classes/dir2
> to be created from classes/dir1.
> is already on CLASSPATH and it is also included in "external jars
> list" in my project
> Dominik
FUDForum. Page generated in 0.08341 seconds
