Home » Archived » M2M (model-to-model transformation) » [ATL] Run Problem On Linux
[ATL] Run Problem On Linux [message #1671] Thu, 21 December 2006 04:46 Go to next message
I am trying example of Starter's guide but unfortunately i couldn't make
it run. Everything ready but in Eclipse Run menu i couldn't select "ATL
File Name" because there is no elements inside combo box. I couldn't try
with ATL Bundle because i am using Linux. I am sending screenshots as
attachment. Everything worked just couldn't select ATL File Name :( to be
able to run.
Thanks.
Screenshots:
http://yzgrafik.ege.edu.tr/~tekrei/resimler/atl1.png
http://yzgrafik.ege.edu.tr/~tekrei/resimler/atl2.png
Re: [ATL] Run Problem On Linux [message #1682 is a reply to message #1671] Thu, 21 December 2006 06:13 Go to previous messageGo to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
--------------000803050609050206040701
Hi Tahir,
What is your ATL version?
Otherwise (as a tempory solution ;-)), you can create manually launch
configuration. Please find enclosed an example for Author2Person.
Freddy.
Tahir Emre KALAYCI a
Re: [ATL] Run Problem On Linux [message #2733 is a reply to message #1682] Thu, 21 December 2006 10:29 Go to previous message
Versions:
Java -> java version "1.6.0" Java(TM) SE Runtime Environment (build
1.6.0-b105) Java HotSpot(TM) 64-Bit Server VM (build 1.6.0-b105, mixed
mode)
Eclipse -> Version: 3.3.0 Build id: I20061102-1715
ATL Development Tools -> 1.0.1.0.20061212
I also downloaded and installed Epsilon because of encore registration
problem.
Running launch configurations worked.
Thanks.
Previous Topic:Launching ATL programmatically
Next Topic:[ATL] accessing sub-package elements in metamodels
Current Time: Sat Jul 12 00:03:22 EDT 2025
Powered by FUDForum. Page generated in 0.05082 seconds
