ant build, go to line of error [message #207716] |
Thu, 23 June 2005 16:11  |
Originally posted by: none.not.no
It appears that eclipse doesn't allow me to go to the line of the next
build error, if I use ant, is that right? I can go to the line in the
build.xml file, but that doesn't help me when the error is in a java
file.
Re: ant build, go to line of error [message #207840 is a reply to message #207757] |
Fri, 24 June 2005 10:12  |
Please log a bug report against Platform Ant with full details so we can
consider this enhancement for post 3.1
Darins
"Frank Fredstone" <none@not.no> wrote in message
news:87aclgfvii.fsf@not.no...
>I was using 3.0, I get the same result with 3.1 RC2, but it's actually
> only errors from checkstyle that are not being clickable. I see now
> that something like a syntax error is clickable. It would be nice if
> variations on filename:line were matched in the console output, and
> made clickable.
> "Darin Swanson" <Darin_Swanson@us.ibm.com> writes:
>> This would be incorrect on the latest 3.1 builds...attached picture shows
>> the linkage for a simple test build
>> Clicking on the link for the Testing.java compile error will take you to
>> line 10 in that file.
>> What build are you using?
>> Darins
>> news:874qboal57.fsf@not.no...
>>> file.
FUDForum. Page generated in 0.04010 seconds
