Automatic-connection to an existing Node [message #207700] |
Fri, 20 January 2006 04:29  |
Originally posted by: strayduck.rhathymia.net
I made a simple editor that is able to add Node and to connect between Nodes (similar to 'Shape editor' sample).
So next I want to change the behavior as shown below:
1.) Each node can have *only one or two* Connections, which means the tree is linear, Node is either root or leaf. Root-node has one Connection to leaf, Leaf-node has one or two Connections (one point to root or leaf, another is pointed to from child-leaf).
2.) When adding new Node,
2-1.) If there are Node(s), new Node is connected to the tail Node automatically.
2-2.) If there is no Node, just new Node add.
I'd read past archives here, and found it's impossible that two actions or commands per one event.
Is there alternative resolutions?
Re: Automatic-connection to an existing Node [message #207710 is a reply to message #207700] |
Fri, 20 January 2006 05:37  |
Originally posted by: ingo.koch[nospam].sap.com
"strayDuck" <strayduck@rhathymia.net> wrote in message
news:32759050.1137749407003.JavaMail.root@cp1.javalobby.org...
> Hello,
automatically.
that
FUDForum. Page generated in 0.07261 seconds
