Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Adding custom types in SourceModule
Adding custom types in SourceModule [message #20000] Wed, 23 January 2008 03:56 Go to next message
Hi people,
I'm new to the dltk framework. I'm using Dltk 1.0.0 release on eclipse 3.3.
We have language for which is have developed grammar in ANTLR 3.0. Now in
our language we have specific types such as label/subroutine; in which
case, these types doesnot fit into the types already provided by
SourceModule. So how do i add new types, say, Label/SubRoutine to the
SourceModule (using requestor)?
I followed the following approach:
1) I extended from SourceField to create LabelField.
2) I extended MySourceModuleRequestor from SourceModuleStructureRequestor;
but i was not able to instantiate it.
3) I inherited ISourceElementRequestor to have IMySourceElementRequestor
and added enterLabel() method. But the infostack object used is private to
ISourceElementRequestor and i cannot use it.
Is there any other approach to add your own types in SourceModule?
Please help. Thank you in advance.
~abhijit.
Re: Adding custom types in SourceModule [message #20040 is a reply to message #20000] Wed, 23 January 2008 08:03 Go to previous messageGo to next message
Hi Abhijit,
DLTK doesn't support adding of custom types to DLTK structure model.
Classes are not final because it is required by internal implementation.
They should not be subclassed.
You should map your language elements to standard elements (like type, field, method).
To provide some customization you could use modifiers.
In future versions we will provide custom renderer's for script explorer and outline, to display custom content.
Andrei Sobolev.
> Hi people,
> in our language we have specific types such as label/subroutine; in
> which case, these types doesnot fit into the types already provided by
> SourceModuleStructureRequestor; but i was not able to instantiate it.
> to ISourceElementRequestor and i cannot use it.
> ~abhijit.
Re: Adding custom types in SourceModule [message #20103 is a reply to message #20040] Wed, 23 January 2008 10:05 Go to previous message
hi Andrie,
Thanks for the reply. I wanted to ask one more thing: when will we be
expecting the next release of dltk?
regards,
Abhijit.
Previous Topic:vertical line numbers
Next Topic:Custom Views that depend on SourceModule
Current Time: Sat Jun 07 22:17:18 EDT 2025
Powered by FUDForum. Page generated in 0.04690 seconds
