Does svn+ssh work with the Subversive SVN Connector and SVNKit 1.1.7? [message #19996] |
Tue, 27 May 2008 21:33  |
I am having a problem with accessing my subversion repository using
svn+ssh: protocol. I have the latest 0.7.0 subversive client installed
with the latest SVN connector and SVNKit 1.1.7. Does anyone else have
this working reliably?
I don' have any problems connecting to the repository using svn+ssh:
using the svn command line client or with the client in IntelliJ.
Any feedback would be appreciated.
Keith
Re: Does svn+ssh work with the Subversive SVN Connector and SVNKit 1.1.7? [message #20185 is a reply to message #20182] |
Thu, 29 May 2008 02:51   |
On 05/28/08 18:48, Keith Fetterman wrote:
> When I browse a repository location in the "SVN Repositories" view, I
> get the error "<An error occurred while accessing the repository entry>".
> If I select the error message and then select "Details" in the context
> menu, I get the detailed error message:
> Get repository folder children operation failed.
> svn: authentication cancelled
> I logged into the server that is hosting the subversion repository and
> looked at the /var/log/auth.log file to see if there are any connection
> errors and I see the following error messages repeated multiple times:
> May 21 07:18:53 tatooine sshd[17225]: Failed password for kdf from
> 63.249.23.59
Hmmm, I remember of problems with the password access sometimes if I upgrade something in Eclipse.
But that does not seem related to a specific Subversive release...
> Earlier releases of subversive 0.7 would prompt me for a password. I do
> not have the "Saved password" checked in the "Edit Repository Location"
> dialog.
Just an idea: Try to use the saved password, you could remove it later if it works.
Perhaps you change your password before if you really dislike saving it in Eclipse.
Cheers, Jörg
> I just tried deleting my repository location and adding it again. I was
> able to create the location and browse the repository. If I restart
> Eclipse, then I get the same problem as before.
> Any ideas? Or is this a bug that I need to report?
> Thanks a lot.
> Keith
> Jörg Thönnes wrote:
>> Yesterday we upgraded our installation to use SVNKit 1.1.7 and the latest
>> SVN Team Provider 0.7.0.v20080521. We could do check-ins and update
>> from SVN
>> repository.
>> Please, could you be more specific about your problems?
>> Cheers, Jörg
>>> Thanks,
>>> Keith
Re: Does svn+ssh work with the Subversive SVN Connector and SVNKit 1.1.7? [message #20197 is a reply to message #20185] |
Tue, 03 June 2008 14:00   |
Hi Jörg,
I tried the idea of saving the password. It still didn't work. I did
find a stack trace in the eclipse .log file. It looks like the problem
is in the SVNKit 1.1.7 library. I have attached the stack trace below
if anyone has any ideas. What does "authentication cancelled" mean?
I guess I need to post this problem SVNKit mailing list.
Stack Trace:
org.eclipse.team.svn.core.connector.SVNConnectorException: svn:
org.polarion.team.svn.connector.svnkit.SVNKitConnector.handl eClientException(SVNKitConnector.java:1172)
org.polarion.team.svn.connector.svnkit.SVNKitConnector.info( SVNKitConnector.java:839)
org.eclipse.team.svn.core.extension.factory.ThreadNameModifi er.info(ThreadNameModifier.java:675)
org.eclipse.team.svn.core.utility.SVNUtility.info(SVNUtility .java:384)
org.eclipse.team.svn.core.svnstorage.SVNRepositoryContainer. getRevisionImpl(SVNRepositoryContainer.java:101)
org.eclipse.team.svn.core.svnstorage.SVNRepositoryResource.g etRevision(SVNRepositoryResource.java:97)
org.eclipse.team.svn.ui.operation.GetRemoteResourceRevisionO peration.runImpl(GetRemoteResourceRevisionOperation.java:39)
org.eclipse.team.svn.core.operation.AbstractActionOperation. run(AbstractActionOperation.java:76)
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT ask(ProgressMonitorUtility.java:103)
org.eclipse.team.svn.core.operation.CompositeOperation.runIm pl(CompositeOperation.java:94)
org.eclipse.team.svn.core.operation.LoggedOperation.run(Logg edOperation.java:37)
org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:89)
org.eclipse.team.svn.ui.utility.DefaultCancellableOperationW rapper.run(DefaultCancellableOperationWrapper.java:55)
org.eclipse.team.svn.ui.utility.ScheduledOperationWrapper.ru n(ScheduledOperationWrapper.java:37)
Caused by: org.tigris.subversion.javahl.ClientException: svn:
org.tigris.subversion.javahl.JavaHLObjectFactory.throwExcept ion(JavaHLObjectFactory.java:607)
org.tmatesoft.svn.core.javahl.SVNClientImpl.throwException(S VNClientImpl.java:1389)
org.tmatesoft.svn.core.javahl.SVNClientImpl.info2(SVNClientI mpl.java:1221)
org.polarion.team.svn.connector.svnkit.SVNKitConnector.info( SVNKitConnector.java:831)
... 15 more
Caused by: org.tmatesoft.svn.core.SVNCancelException: svn:
org.tmatesoft.svn.core.internal.wc.SVNErrorManager.cancel(SV NErrorManager.java:30)
org.tmatesoft.svn.core.internal.wc.DefaultSVNAuthenticationM anager.getNextAuthentication(DefaultSVNAuthenticationManager .java:202)
org.tmatesoft.svn.core.internal.io.svn.SVNSSHConnector.open( SVNSSHConnector.java:84)
org.tmatesoft.svn.core.internal.io.svn.SVNConnection.open(SV NConnection.java:60)
org.tmatesoft.svn.core.internal.io.svn.SVNRepositoryImpl.ope nConnection(SVNRepositoryImpl.java:974)
org.tmatesoft.svn.core.internal.io.svn.SVNRepositoryImpl.get LatestRevision(SVNRepositoryImpl.java:140)
org.tmatesoft.svn.core.wc.SVNBasicClient.getRevisionNumber(S VNBasicClient.java:348)
org.tmatesoft.svn.core.wc.SVNBasicClient.getLocations(SVNBas icClient.java:462)
org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SV NBasicClient.java:418)
org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SV NBasicClient.java:382)
org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.jav a:1988)
org.tmatesoft.svn.core.javahl.SVNClientImpl.info2(SVNClientI mpl.java:1207)
... 16 more
>> 63.249.23.59
>> dialog.
> Cheers, Jörg
>> Thanks a lot.
>> Keith
>>> from SVN
>>> repository.
>>> Cheers, Jörg
>>>> Thanks,
>>>> Keith
Re: Does svn+ssh work with the Subversive SVN Connector and SVNKit 1.1.7? [message #20718 is a reply to message #20197] |
Tue, 10 June 2008 12:18  |
From reading the post Re: "Newby: Linux Connector"
news://news.eclipse.org:119/4af23d253052b0d2cbab24afe6c0e7e8 $1@www.eclipse.org
I was able to get the JavaHL 1.4.4 connector to work on my Ubuntu
system. Given this, I feel stronger that my problems connecting to the
repository via svn+ssh protocol were in the latest SVNKit 1.1.7 library.
> Hi Jörg,
> Stack Trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> at
> at
> ... 15 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 16 more
>>> entry>".
>>> 63.249.23.59
>>> dialog.
>> if it works.
>> it in Eclipse.
>> Cheers, Jörg
>>> Thanks a lot.
>>> Keith
>>>> latest
>>>> from SVN
>>>> repository.
>>>> Cheers, Jörg
>>>>> installed
>>>>> Thanks,
>>>>> Keith
FUDForum. Page generated in 0.04727 seconds
