Home » Archived » Maven Integration (M2E) » Eclipse-Plugins as consumeable Maven-Artifacts?
Eclipse-Plugins as consumeable Maven-Artifacts? [message #19986] Fri, 19 December 2008 00:04 Go to next message
We (the UFaceKit team [1]) are building and assembling all our code and
workspace setup using maven but until now we did find a repository of
Eclipse plugins we could consume.
My question you is do:
a) Is providing Eclipse-Plugins as maven-artifacts scope of these one of
these projects or do you all work on tooling
b) If you don't provide such a thing do you by chance now a public repo
which we can use to consume them? Until now we maintained our own but
if there's a public one available this would be the better way
Tom Schindl / UFaceKit Project Lead
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Eclipse-Plugins as consumeable Maven-Artifacts? [message #20026 is a reply to message #19986] Fri, 19 December 2008 01:21 Go to previous messageGo to next message
The scope of the project is
Re: Eclipse-Plugins as consumeable Maven-Artifacts? [message #20064 is a reply to message #19986] Fri, 19 December 2008 01:33 Go to previous messageGo to next message
Hello Tom,
a) The scope of IAM is limited to tooling.
b) Some eclipse bundles have been uploaded to maven central repo in the
past by Carlos Sanchez[1] who is an IAM co-lead. However, the versions
there are not up to date.
This said, we have been talking internally about initiating the job of
creating a maven repository at the Eclipse Foundation populated with
eclipse plugins. Would you be interested in helping with this? We would
need to talk to the Architecture Council, Committer Representatives, etc...
[1] http://www.jroller.com/carlossg/entry/eclipse_jars_now_in_ma ven
Tom Schindl wrote:
Re: Eclipse-Plugins as consumeable Maven-Artifacts? [message #20094 is a reply to message #19986] Fri, 19 December 2008 11:41 Go to previous message
Originally posted by: igor.ifedorenko.com
Tom,
Part of m2e goal is to provide first class support for building
eclipse/osgi bundles with maven. We call this maven based eclipse/osgi
build tool "Tycho". It won't provide existing eclipse bundles in maven
repository per se, but will allow you to use eclipse artifacts directly
from p2 repositories and local eclipse installations. You will be able
to use maven repositories to share tycho-built artifacts, however.
You can read more about Tycho on m2e wiki [1] and I can provide more
details if you have questions.
[1] http://docs.codehaus.org/display/M2ECLIPSE/Tycho+project+ove rview
Igor
Tom Schindl wrote:
Previous Topic:The newest maven repo for eclipse artifacts and osgi bundles
Next Topic:Re: Problem using maven and wtp (resources and libraries are not handle correctly)
Current Time: Fri Jul 18 02:07:12 EDT 2025
Powered by FUDForum. Page generated in 0.32016 seconds
