Home » Archived » BIRT » expression builder in birt
expression builder in birt [message #207210] Tue, 19 December 2006 01:20 Go to next message
is that anyone can show me how to use the "report parameter" in the
expression builder for a data?
how can i write the expression with the report parameter?
thanks.
Re: expression builder in birt [message #207352 is a reply to message #207210] Tue, 19 December 2006 10:47 Go to previous messageGo to next message
If you just want to display it use
params["ParameterName"] as the expression.
Jason
"70" <klhuang@shinyang.com.my> wrote in message
news:45285403ac257ee3eedcd3c5430a1a39$1@www.eclipse.org...
> thanks.
Re: expression builder in birt [message #207463 is a reply to message #207352] Tue, 19 December 2006 19:08 Go to previous messageGo to next message
how can i write the script if i wish to use the report parameter as a
filter for my report?
Re: expression builder in birt [message #207732 is a reply to message #207463] Wed, 20 December 2006 12:37 Go to previous messageGo to next message
Here is an example that filters the dataset based on a parameter.
Jason
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.1.v20060922-1058 Build &lt;20060926-0959></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company Name
here>></property>
<parameters>
<scalar-parameter name="ProdCode" id="6">
<property name="valueType">dynamic</property>
<property name="dataType">string</property>
<property name="controlType">list-box</property>
<property name="dataSetName">prodcd</property>
<expression name="valueExpr">dataSetRow["PRODUCTCODE"]</expression>
<property name="mustMatch">false</property>
<property name="defaultValue">S18_1749</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
name="Data Source" id="4">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<encrypted-property name="odaPassword"></encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="5">
<list-property name="filter">
<structure>
<property name="operator">eq</property>
<expression name="expr">row["PRODUCTCODE"]</expression>
<expression name="value1">params["ProdCode"]</expression>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails</property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0"
encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
<design:attributes>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="prodcd" id="41">
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<property name="queryText">select CLASSICMODELS.PRODUCTS.PRODUCTCODE
from products</property>
encoding="UTF-8"?>
<model:DesignValues
<design:attributes>
<design:usageHints>
<design:attributes>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="7">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="36"/>
<column id="37"/>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<header>
<row id="8">
<cell id="9">
<label id="10">
<text-property name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="11">
<label id="12">
<text-property name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="19">
<cell id="20">
<data id="21">
<property name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="22">
<data id="23">
<property name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="24">
<data id="25">
<property name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="30">
<cell id="31"/>
<cell id="32"/>
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
</row>
</footer>
</table>
</body>
</report>
news:278991d756c9dd414a8c60541e83b52d$1@www.eclipse.org...
Re: expression builder in birt [message #207905 is a reply to message #207732] Wed, 20 December 2006 19:39 Go to previous message
okay jason....thanks a lot... ^o^
Previous Topic:Maximum Data Set Size for BIRT?
Next Topic:Page Totals Possible?
Current Time: Sun Nov 09 05:32:46 EST 2025
Powered by FUDForum. Page generated in 0.03944 seconds
