Home » Eclipse Projects » GEF » How to reflect model state in a custom view after Undo
How to reflect model state in a custom view after Undo [message #207169] Wed, 11 January 2006 11:37 Go to next message
I wonder if anyone can help me understand how views reflect the state of a
model after an Undo command has been issued. I have built a GEF editor
with undoable/redoable GEF commands to edit my model. I use both the
standard Properties view and Outline view to support my editor. Using gef
commands and the command stack of my editor I can change properties of the
elements in my model through the properties view and my gef Figures are
updated appropriately. Also when I undo one of these commands my Figures
are updated appropriately and the Properties view and the Outline view is
also updated appropriately.
My problem is that I also have another View which I've created myself. Its
state is not updated to reflect the new state of my model after an Undo,
and I can't understand why. What is it that the standard Properties and
Outline views are doing that my view is not doing.
The only listener which my view currently implements is ISelectionListener
to listen to selection changes within my editor. Obviously I could make my
view also listen to property changes within my model in the same way as my
edit parts do, but I don't see how the standard Properties and Outline
views could be doing that, and I don't want my view to operate in a
non-standard manner.
Can anybody enlighten me?
Thanks in advance
Neil
Re: How to reflect model state in a custom view after Undo [message #207306 is a reply to message #207169] Thu, 12 January 2006 16:40 Go to previous message
Your diagram is updated from the model because the model fires events to the
EditParts whenever something relevant changes. If your view is based on
EditParts listening to these events, it will update. Take a look at the GEF
ediagram example which is available from CVS.
"Neil Sanderson" <neil.sanderson@scapatech.com> wrote in message
news:233120d37535c8eb4ff3c116503715af$1@www.eclipse.org...
> Hello,
> Thanks in advance
> Neil
Previous Topic:Running/Editing the examples
Next Topic:Shold I start from EMF or GMF?
Current Time: Fri Jul 18 15:37:15 EDT 2025
Powered by FUDForum. Page generated in 0.02496 seconds
