Home » Modeling » GMF (Graphical Modeling Framework) » Remove the horizontal line in the middle of Compartment?
Remove the horizontal line in the middle of Compartment? [message #207149] Fri, 26 September 2008 07:00 Go to next message
in compartments there is a horizontal line above which stays the Label of
the compartment. Normally this line is just under the Label, but somehow
it happened to me that the line now is in the middle of the compartment.
And now the compartments are divided in upper (empty) and bottom (where
elements are added) part, but I would like them as before.
Here is a picture of a compartment:
http://posithing.com/temp/pics/gmf-line-in-the-middle.bmp
You can see that after an element is added to the compartment, the line
moves upwards.
Do you what could be the reason for it and how can I make the line just
stays under the label? The problem is not in the "List Layout" property.
I'm using Eclipse 3.4.0 and GMF SDK 2.1.0 and GMF Runtime 1.1.0
Greetings,
Nikolay
Re: Remove the horizontal line in the middle of Compartment? [message #207158 is a reply to message #207149] Fri, 26 September 2008 07:34 Go to previous messageGo to next message
Hello Nikolay,
I think you have to add aome layout to the figure of an element containing
this compartment (i remember there was something changed in between of GMF
1.0 and 2.0 in this area..) So, you can try adding FlowLayout into the main
element figure. See oeg.graphdef/models/basic.gmfgraph -> NamedNodeRectangle
figure descriptor as an example.
Alex Shatalin
Re: Remove the horizontal line in the middle of Compartment? [message #207164 is a reply to message #207149] Fri, 26 September 2008 07:40 Go to previous messageGo to next message
Hi Nikolay,
had the same issue, when I moved from GMF 2.0 (or some Milestone of 2.1) to
GMF 2.1.
In your grafdef-model make sure, you set the correct layouts and constraints
for your elements:
My Figure, that looks like yours has the following definition:
RoundedRectangle XXX
- BorderLayout
- Label XXXLabel
- BorderLayoutData Beginning (vertical is set to true)
- Rectangle XXXCompartment
- BorderLayoutData Center (vertical is also set to true)
- Child Access (... for label)
- Child Access (... for comparment)
should do the trick for you.
HTH
Thomas
"Nikolay Georgiev" <erdtek@gmail.com> schrieb im Newsbeitrag
news:0b9cbfc4806cef3d36a373cb0e3abcdd$1@www.eclipse.org...
> Hello,
> moves upwards.
> Greetings,
> Nikolay
Re: Remove the horizontal line in the middle of Compartment? [message #207564 is a reply to message #207158] Tue, 30 September 2008 14:09 Go to previous messageGo to next message
Hi Alex,
I tried it and the line was moved in the right position! (that was good
:), but then maybe because the container has as layout FlowLayout, I
couldn't add the elements at each position I wanted in the container, for
example I couldn't add an element under an already added element (The
mouse pointer disallowed it), it worked only at its left or right side a
container in my bigger container.
If had only a container without nothing, then I couldn't add elements to
it by clicking in the middle of it. There was only some small area in the
upper/left side of the container where it was allowed for the mouse cursor
to click.
Maybe I need some other layout ... will check it out ...
Nikolay
Re: Remove the horizontal line in the middle of Compartment? [message #207579 is a reply to message #207164] Tue, 30 September 2008 16:11 Go to previous message
Hi Thomas,
Thank you very much for the layout information! It works :))
Nikolay
Previous Topic:Modify palette tool to copy existing resource
Next Topic:Scheme editor, ecore to gmf
Current Time: Wed Jul 02 08:46:23 EDT 2025
Powered by FUDForum. Page generated in 0.40196 seconds
