Aperi_R0.2_Binary.zip install problems [message #206996] |
Mon, 23 April 2007 18:37  |
Originally posted by: tony.bar.gmail.com
Apologize if this has already been asked, I'm trying to install the
milestone release from download.
I've followed the instructions so far, I've installed the java help, the
recommended jar files and exported my path out:
C:\aperi\configure>set path=%path%;C:\Program Files\Java\j2re1.4.2_06\bin
Now I'm trying to run cfgaperi and I get the following output:
C:\aperi\configure>cfgaperi
Exception in thread "main" java.lang.UnsupportedClassVersionError:
org/eclipse/aperi/configure/ConfigureAperi (Unsupported major.minor
version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
I'm not sure what the problem is here, any help greatly appreciated.
Re: Aperi_R0.2_Binary.zip install problems [message #207421 is a reply to message #206996] |
Wed, 25 April 2007 06:24  |
> version 49.0)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
Your Java application is compiled for a Java 5.0 JVM and you are using
Java 1.4.2. You need to upgrade your JVM/JDK to a Java 5.0 (1.5.x) JVM
or better.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
FUDForum. Page generated in 0.09266 seconds
