Home » Modeling » M2T (model-to-text transformation) » new to JET2
new to JET2 [message #19947] Tue, 05 June 2007 07:42 Go to next message
I'd like to use JET2 to generate a "custom" xml file from a xmi file
generated by GMF plugin. The input file is based on a GMF Tutorial and
looks like this:
<mindmap:map xmlns:mindmap="http://www.example.org/mindmap">
<rootTopics name="myTopic" subtopics="#//@map/@rootTopics.1">
<comments subject="myThread">
<items body="a ThreadI tem"/>
</comments>
</rootTopics>
<rootTopics name="AnotherTopic"/>
<rootTopics name="Third Topic"/>
<partitions name="Partition1"/>
<partitions name="Partition2"/>
</mindmap:map>
I'd like to iterate through the different elements to get their values. In
my template jet file I have :
<c:iterate select="/mindmap:map/rootTopics" var="currNode">
Name = <c:get select="$currNode/@name" />
</c:iterate>
But I obtain this error:
Error: No namespace URI found for prefix "mindmap"
The problem comes obviously from the "mindmap:map" tag but I don't know
the correct syntax to access its elements.
Thank you for your help.
Re: new to JET2 [message #20032 is a reply to message #19947] Tue, 05 June 2007 08:46 Go to previous messageGo to next message
Tex:
Try:
<c:iterate select="/map/rootTopics" var="currNode">
</c:iterate>
JET doesn't currently have a mechanism to map namespace prefixes such as
'mindmap' to a namespace URI. To compensate, the relaxes the matching of
/map. Technically, it should not match mindmap:map, but it does.
Paul
"Tex Twil" <chaljan@hotmail.com> wrote in message
news:1d04f0fe4783c087432b0c6c80d4a244$1@www.eclipse.org...
> Hello,
> looks like this:
> </comments>
> </rootTopics>
> </mindmap:map>
> <c:iterate select="/mindmap:map/rootTopics" var="currNode"> Name = <c:get
> </c:iterate>
Re: new to JET2 [resolved] [message #20650 is a reply to message #20032] Tue, 05 June 2007 10:14 Go to previous message
Thank you Paul, it seems to work.
Paul Elder wrote:
> Tex:
> Try:
> </c:iterate>
> Paul
>> Hello,
>> looks like this:
>> <?xml version="1.0" encoding="UTF-8"?>
>> </comments>
>> </rootTopics>
>> </mindmap:map>
>> </c:iterate>
Previous Topic:JET2 access to ecore references... again
Next Topic:Re: creating a jet project
Current Time: Fri Jul 18 00:41:19 EDT 2025
Powered by FUDForum. Page generated in 0.27527 seconds
