Problem with Eclipse starting up [message #19899] |
Mon, 05 May 2003 09:28  |
Originally posted by: eclipse.wingspread.fastmail.fm
I'm using Eclipse 2.1 on a Windows XP machine. Yesterday Eclipse crashed
due to an out of memory condition. The out of memory condition happened
during a build of an AspectJ project. Since that time I have been unable
to open Eclipse without getting errors on startup or exit. Some of the
errors seem to relate to the AJDT plugin. When I start Eclipse, I see
information such as the following in my log:
!SESSION May 05, 2003 08:55:01.110 -----------------------------------------
java.version=1.4.1_01
Command-line arguments: -os win32 -ws win32 -arch x86 -install
file:C:/dev/java/eclipse2.1/
!ENTRY org.eclipse.core.runtime 4 2 May 05, 2003 08:55:01.110
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2332)
at org.eclipse.swt.SWT.error(SWT.java:2262)
at org.eclipse.swt.widgets.Widget.error(Widget.java:385)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:246)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:237)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:190)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:128)
org.eclipse.jface.resource.FontRegistry.defaultFont(FontRegi stry.java:293)
at org.eclipse.jface.resource.FontRegistry.get(FontRegistry.jav a:370)
org.eclipse.jface.resource.JFaceResources.getFont(JFaceResou rces.java:183)
at org.eclipse.jdt.internal.ui.JavaPlugin.startup(JavaPlugin.ja va:241)
!ENTRY org.eclipse.core.runtime 4 2 May 05, 2003 08:55:01.157
!MESSAGE Plug-in org.eclipse.ajdt.ui was unable to load class
org.eclipse.ajdt.internal.builder.Builder.
!STACK 0
org.eclipse.core.internal.boot.DelegatingLoaderException:
org.eclipse.core.runtime.CoreException: Problems encountered starting up
plug-in: "org.eclipse.jdt.ui".
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivation(PluginDescriptor.java:746)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:188)
org.eclipse.core.internal.plugins.PluginClassLoader.activate Plugin(PluginClassLoader.java:112)
!ENTRY org.eclipse.core.resources 2 1 May 05, 2003 08:55:01.157
!MESSAGE Skipping builder org.eclipse.ajdt.ui.ajbuilder for project CACM.
Either the builder is missing from the install, or it belongs to a project
nature that is missing or disabled.
!ENTRY org.eclipse.core.runtime 4 2 May 05, 2003 08:55:01.188
!STACK 0
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gatingLoaderException:
Attempt to load class "org.eclipse.ajdt.internal.builder.Builder" from
deactivated plug-in "org.eclipse.ajdt.ui".
org.eclipse.core.internal.plugins.PluginClassLoader.shouldLo okForClass(PluginClassLoader.java:255)
org.eclipse.core.internal.plugins.PluginClassLoader.internal FindClassParentsSelf(PluginClassLoader.java:174)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.find ClassParentsSelf(DelegatingURLClassLoader.java:485)
!ENTRY org.eclipse.core.resources 2 1 May 05, 2003 08:55:01.188
CreditGrades Workbench. Either the builder is missing from the install, or
it belongs to a project nature that is missing or disabled.
!ENTRY org.eclipse.core.runtime 4 2 May 05, 2003 08:55:01.219
!STACK 0
Clearly something is hosed in my setup. The question is what, if anything,
can I do to get things working properly again? Based on a suggestion in
the eclipse.platform group I'm going to remove the adjt plugin and see what
happens. Has anyone else had this sort of problem when using the AJDT
plugin?
Thanks.
James Howe
Re: Problem with Eclipse starting up [message #21766 is a reply to message #19899] |
Thu, 15 May 2003 15:39  |
Originally posted by: eclipse.bothfeld.de
>> ... Since that time I have been unable to open
>> see information such as the following in my log:
I encountered similar problems after creating new AspectJ projects.
After that I am unable open editors and most of the IDE is not working
at all.
> working properly again? Based on a suggestion in the
> see what happens. Has anyone else had this sort of problem when
> using the AJDT plugin?
By accidence I found a work around that might help you too:
I always keep a dummy (pure Java!) project called tmp, containing no
source at all. When I run into trouble I just cose all projects delete
my tmp project physically and create it again as it has been before - empty.
I don't know why but it works although it sounds really weird.
Hope this helps
Kay
Re: Problem with Eclipse starting up [message #566227 is a reply to message #19899] |
Thu, 08 May 2003 11:39  |
> plugin?
> Thanks.
> James Howe
It would seem that your metadata for the AJDT plugin is corrupted. This
has not happened to me since using 2.1 as Eclipse has become much more
reliable. I suspect the problem stems from the catastrophic failure though
the OutOfMemoryError. Firstly try removing just the metadata for the AJDT
plugin by deleting the following directory:
/eclipse/workspace/.metadata/.plugins/org.eclipse.ajdt.ui
Re: Problem with Eclipse starting up [message #567168 is a reply to message #19899] |
at all.
Hope this helps
Kay
FUDForum. Page generated in 0.28878 seconds
