Configurable Operators for Report Parameters [message #206414] |
Thu, 14 December 2006 15:35 |
Originally posted by: pvmurthy.effigent.com
Hi All,
We have integrated BIRT Runtime into a tapestry web application and are
able to run reports from within the WebApplication environment.
We have a generic parameters page -- which queries any report design
file and renders the parameters for the report. When the user enters
values they are used in the run and render task -- and we output the
report in the format desired. All is fine until here.
Now, We want to provide a feature where the Operator used for the
parameter itself is configurable -- >>>>>
something like this --
Select empid, empname from employee where empid ? ?
i,e, the Operator could either be -- "=","<",">","!="
Similarly for strings we want to provide begins with, ends with, and
contains
and for Dates (most importantly) -- we would like to provide date range,
> Date, < Date etc.
So the question is -- is there a way to manipulate the Operators used
within the report queries?
Or Else,
Should I go about extracting the report query, modifying it, and placing
it back? If so, is there any example for this apprach.
Thanks for your help,
Cheers
Murthy
FUDForum. Page generated in 0.04499 seconds
