code assist doesn't pop up... [message #19885] |
Sat, 29 January 2005 02:11  |
Originally posted by: db0815.web.de
Hi :)
I am experimenting with the first "Hello World" example in the
book "Eclipse" by Steve Holzner, O'Reilly and entered the following code:
public class Ch01_01 {
System.
The book ordered me to enter "System." and to wait for the code assist
popping up ....... I am waiting for two hours now - but nothing happened :(
I am using the emacs key mappings - could this be the reason?
Even after pushing [Ctrl]-[Space] nothing happened.
Do I have to activate code assist somewhere??
Thanks for any Help, Die
Re: code assist doesn't pop up... [message #20665 is a reply to message #19929] |
Sat, 29 January 2005 10:26  |
Originally posted by: db815.web.de
Hi Sander,
- there was no error in my code,
- the name was ok,
- the L was there also,
- and for some reason ... !?: even code assist worked...! - ?? - !?!!
Computers are strange beeings!
Thanks a lot for your help, Die :)
> Maybe there is an error in your code so fare; look for red underlining.
> Check the file is named Ch01_01.java. Maybe you show the file in the
> text-editor instead of the java-editor; check icon in the tab of the editor
> it should be a page with a J on it. I hope this helps,
> Sander
FUDForum. Page generated in 0.08200 seconds
