Where does Eclipse get System.properties [message #206267] |
Thu, 19 April 2007 23:24  |
Originally posted by: stevetierney.gmail.com
I have a J2EE app that I am developing in Eclipse for deployment on Tomcat.
I am using the JAXB/JAXME jars to create an XML file.
If I run the program from within Eclipse, my XML file generates fine.
When I run from Tomcat on the same box, it fails.
I wrote a small loop to print out all of the system properties and their
values.
For the system property of java.class.path, when printed on the code that
executes in Eclipse, I see all of the jaxb/jaxme jars. However, when I
deploy my code to Tomcat, on the same box as Eclipse, the java.class.path
value is different and doesn't include my jaxb/jaxme jars.
Can anyone tell me how reading in of the java.class.path varies between
Tomcat and Eclipse on the same box...and if my problem is really with
Eclipse...or should I be looking at Tomcat?
Kind Thanks,
B
Re: Where does Eclipse get System.properties [message #206428 is a reply to message #206267] |
Fri, 20 April 2007 10:01  |
Nevermind, I have figured it out.
It looks like my ant script is specifying the libs that I see when
printing my properties from w/in eclipse.
Now off to Tomcat to figure out what I need to do there to have it find my
scripts.
Thanks for taking the time to read this!
FUDForum. Page generated in 0.58621 seconds
