[ATL] how to convert hierachies like Class with Operations with Parameters ? [message #19872] |
Thu, 01 March 2007 09:40 |
Originally posted by: walcir.fontanini.cenpra.gov.br
Hi all,
The "Parameter" target pattern in rule ClassToEntityComponent (see
UML2EJB.atl file) was supposed to produce a list of parameters, but it
is not working. The UML!CLASS has a composite part UML!Operation and
UML!Operation has another composite part UML!Parameter. How to reflect
this hierarchy in rule ClassToEntityComponent ? Any hint for me ?
-walcir
=================Output.ecore ==========================================
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="EJB">
<EJBEntityComponent name="Customer" usedTable="/1">
<feature xsi:type="EJBBusinessMethod" name="createOrder">
<parameter/>
</feature>
</EJBEntityComponent>
<Table/>
<EJBEntityComponent name="BreakfastOrder" usedTable="/3">
<feature xsi:type="EJBBusinessMethod" name="calculatePrice">
<parameter name="year_price"/>
</feature>
<feature xsi:type="EJBBusinessMethod" name="calcPriceOO">
<parameter name="year_priceoo"/>
</feature>
<Table/>
<EJBEntityComponent name="StandardBreakfast" usedTable="/5"/>
<Table/>
</xmi:XMI>
=======UML2EJB.atl========================================== ================
module UML2EJB; -- Module Template
create OUT : EJB from IN : UML ;
-- Tested: OK
helper context UML!Class def: getAssociationEnds(): Sequence(
UML!AssociationEnd) =
let associationEnds : Sequence(UML!AssociationEnd) = self.feature->
select( e | e.oclIsKindOf(UML!AssociationEnd)) in
if associationEnds->notEmpty() then
associationEnds->iterate( e;
acc: Sequence(UML!AssociationEnd) = Sequence{} |
acc.append(e) )
else
Sequence{}
endif;
-- Tested: OK
helper context UML!Class def:isAComposition(): Boolean =
self.getAssociationEnds()->exists(end | end.otherEnd.composition =
true)
-- tested : ok
helper context UML!Class def: operations(): Sequence(UML!Operation) =
let operations : Sequence(UML!Operation) = self.feature->
select( e | e.oclIsKindOf(UML!Operation)) in
if operations->notEmpty() then
operations
-- operations->iterate( e;
-- acc: Sequence(UML!Operation) = Sequence{} |
-- acc.append(e) )
else
Sequence{}
endif
rule ClassToEntityComponent{
from class : UML!Class
( not class.isAComposition() )
to entityComponent : EJB!EJBEntityComponent (
name <- class.name,
feature <- Features,
usedTable <- EJBTable
EJBTable : EJB!Table (
Features : distinct EJB!EJBBusinessMethod
foreach (oper in class.operations()) (
name <- oper.name,
parameter <- Parameters
Parameters : distinct EJB!EJBParameter
name <- oper.parameter->first().name
=========UMLinput4.ecore==================================== =============
<?xml version="1.0" encoding="ASCII"?>
xmlns="UML">
<DataType name="String"/>
<DataType name="Integer"/>
<Class name="BreakfastOrder">
<feature xsi:type="Attribute" name="deliveryStatus" type="/0"/>
<feature xsi:type="Attribute" name="deliveryDate" type="/0"/>
<feature xsi:type="Operation" name="calculatePrice">
<parameter name="year_price" type="/1"/>
<parameter name="rate" type="/1"/>
</feature>
<feature xsi:type="AssociationEnd" name="customer" lower="1"
upper="1" otherEnd="/3/@feature.3"/>
<feature xsi:type="AssociationEnd" name="breakfasts" lower="1"
upper="-1" composition="true" otherEnd="/4/@feature.2"/>
<feature xsi:type="Operation" name="calcPriceOO">
<parameter name="year_priceoo" type="/1"/>
</feature>
</Class>
<Class name="Customer">
<feature xsi:type="Attribute" name="accounNumber" type="/1"/>
<feature xsi:type="Attribute" name="address" type="/1"/>
<feature xsi:type="Operation" name="createOrder"/>
<feature xsi:type="AssociationEnd" name="orders" lower="1"
upper="1" otherEnd="/2/@feature.3"/>
</Class>
<Class name="Breakfast">
<feature xsi:type="Attribute" name="number" type="/1"/>
<feature xsi:type="AssociationEnd" name="standard" lower="1"
upper="1" otherEnd="/5/@feature.3"/>
<feature xsi:type="AssociationEnd" name="order" lower="1" upper="1"
otherEnd="/2/@feature.4"/>
</Class>
<Class name="StandardBreakfast">
<feature xsi:type="Attribute" name="name" type="/0"/>
<feature xsi:type="Attribute" name="style" type="/0"/>
<feature xsi:type="Attribute" name="price" type="/1"/>
<feature xsi:type="AssociationEnd" name="standard_other_end"
upper="-1" otherEnd="/4/@feature.1"/>
</Class>
</xmi:XMI>
package UML {
abstract class Classifier {
attribute name : String;
class DataType extends Classifier {}
class Set extends DataType {
reference elementType : Classifier;
abstract class Typed {
reference type : Classifier;
abstract class Feature extends Typed {
attribute visibility : String;
reference classs : Class oppositeOf feature; -- 'classs' foi usado
como 'class'
class Class extends Classifier {
reference feature[*] container : Feature oppositeOf classs;
class Attribute extends Feature { }
class Parameter extends Typed {
reference operationn : Operation oppositeOf parameter; --
'operationn' foi usado como 'operation'
class Operation extends Feature {
reference parameter[*] container : Parameter oppositeOf operationn;
class AssociationEnd extends Feature {
attribute lower : Integer;
attribute upper : Integer;
attribute composition : Boolean;
reference otherEnd[0-1] : AssociationEnd;
reference association : Association oppositeOf end;
class Association {
reference end[2-*] : AssociationEnd oppositeOf association;
package PrimitiveTypes {
datatype String;
datatype Integer;
datatype Boolean;
package EJB {
abstract class EJBClassifier {
class EJBDataType extends EJBClassifier {}
abstract class EJBTyped {
reference type : EJBClassifier;
abstract class EJBClass extends EJBClassifier {
reference feature[*] container : EJBFeature oppositeOf classs;
class EJBKeyClass extends EJBClass {}
abstract class EJBComponent extends EJBClass {}
class EJBSessionComponent extends EJBComponent {}
class EJBEntityComponent extends EJBComponent {
reference usedTable[1-*] : Table;
class Table {}
class EJBDataSchema {
reference element[*] container : EJBDataSchemaElement oppositeOf
packagee;
abstract class EJBDataSchemaElement {
reference packagee : EJBDataSchema oppositeOf element;
class EJBDataClass extends EJBDataSchemaElement, EJBClass {}
class EJBDataAssociation extends EJBDataSchemaElement {
reference end[2-2] : EJBAssociationEnd oppositeOf association;
abstract class EJBFeature extends EJBTyped {
reference classs : EJBClass oppositeOf feature;
class EJBAttribute extends EJBFeature {}
class EJBBusinessMethod extends EJBFeature {
reference parameter[*] container : EJBParameter oppositeOf operationn;
class EJBParameter extends EJBTyped {
reference operationn : EJBBusinessMethod oppositeOf parameter;
class EJBAssociationEnd extends EJBFeature {
reference association[0-1] : EJBDataAssociation oppositeOf end;
class EJBServingAttribute extends EJBAssociationEnd {}
datatype String;
datatype Integer;
datatype Boolean;
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<ecore:EPackage name="PrimitiveTypes">
<eClassifiers xsi:type="ecore:EDataType" name="String"/>
<eClassifiers xsi:type="ecore:EDataType" name="Integer"/>
<eClassifiers xsi:type="ecore:EDataType" name="Boolean"/>
</ecore:EPackage>
<ecore:EPackage name="EJB">
<eClassifiers xsi:type="ecore:EClass" name="EJBClassifier"
abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
ordered="false" unique="false" lowerBound="1" eType="/0/String"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBDataType"
eSuperTypes="/1/EJBClassifier"/>
<eClassifiers xsi:type="ecore:EClass" name="EJBTyped" abstract="true">
<eStructuralFeatures xsi:type="ecore:EReference" name="type"
ordered="false" lowerBound="1" eType="/1/EJBClassifier"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBClass"
abstract="true" eSuperTypes="/1/EJBClassifier">
<eStructuralFeatures xsi:type="ecore:EReference" name="feature"
ordered="false" upperBound="-1" eType="/1/EJBFeature" containment="true"
eOpposite="/1/EJBFeature/classs"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBKeyClass"
eSuperTypes="/1/EJBClass"/>
<eClassifiers xsi:type="ecore:EClass" name="EJBComponent"
abstract="true" eSuperTypes="/1/EJBClass"/>
<eClassifiers xsi:type="ecore:EClass" name="EJBSessionComponent"
eSuperTypes="/1/EJBComponent"/>
<eClassifiers xsi:type="ecore:EClass" name="EJBEntityComponent"
eSuperTypes="/1/EJBComponent">
<eStructuralFeatures xsi:type="ecore:EReference" name="usedTable"
ordered="false" lowerBound="1" upperBound="-1" eType="/1/Table"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Table"/>
<eClassifiers xsi:type="ecore:EClass" name="EJBDataSchema">
<eStructuralFeatures xsi:type="ecore:EReference" name="element"
ordered="false" upperBound="-1" eType="/1/EJBDataSchemaElement"
containment="true" eOpposite="/1/EJBDataSchemaElement/packagee"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBDataSchemaElement"
abstract="true">
<eStructuralFeatures xsi:type="ecore:EReference" name="packagee"
ordered="false" lowerBound="1" eType="/1/EJBDataSchema"
eOpposite="/1/EJBDataSchema/element"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBDataClass"
eSuperTypes="/1/EJBDataSchemaElement /1/EJBClass"/>
<eClassifiers xsi:type="ecore:EClass" name="EJBDataAssociation"
eSuperTypes="/1/EJBDataSchemaElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="end"
ordered="false" lowerBound="2" upperBound="2"
eType="/1/EJBAssociationEnd" eOpposite="/1/EJBAssociationEnd/association"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBFeature"
abstract="true" eSuperTypes="/1/EJBTyped">
<eStructuralFeatures xsi:type="ecore:EReference" name="classs"
ordered="false" lowerBound="1" eType="/1/EJBClass"
eOpposite="/1/EJBClass/feature"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBAttribute"
eSuperTypes="/1/EJBFeature"/>
<eClassifiers xsi:type="ecore:EClass" name="EJBBusinessMethod"
eSuperTypes="/1/EJBFeature">
<eStructuralFeatures xsi:type="ecore:EReference" name="parameter"
ordered="false" upperBound="-1" eType="/1/EJBParameter"
containment="true" eOpposite="/1/EJBParameter/operationn"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBParameter"
name="operationn" ordered="false" lowerBound="1"
eType="/1/EJBBusinessMethod" eOpposite="/1/EJBBusinessMethod/parameter"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBAssociationEnd"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lower"
ordered="false" unique="false" lowerBound="1" eType="/0/Integer"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="upper"
name="composition" ordered="false" unique="false" lowerBound="1"
eType="/0/Boolean"/>
name="association" ordered="false" eType="/1/EJBDataAssociation"
eOpposite="/1/EJBDataAssociation/end"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EJBServingAttribute"
eSuperTypes="/1/EJBAssociationEnd"/>
</ecore:EPackage>
</xmi:XMI>
-- Tested: OK
acc.append(e) )
else
Sequence{}
endif;
-- Tested: OK
self.getAssociationEnds()->exists(end | end.otherEnd.composition = true)
-- tested : ok
operations
-- acc.append(e) )
else
Sequence{}
endif
name <- class.name,
name <- oper.name,
</ecore:EPackage>
<ecore:EPackage name="UML">
<eClassifiers xsi:type="ecore:EClass" name="Classifier"
abstract="true">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DataType"
eSuperTypes="/1/Classifier"/>
<eClassifiers xsi:type="ecore:EClass" name="Set"
eSuperTypes="/1/DataType">
name="elementType" ordered="false" lowerBound="1" eType="/1/Classifier"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Typed" abstract="true">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Feature"
abstract="true" eSuperTypes="/1/Typed">
name="visibility" ordered="false" unique="false" lowerBound="1"
eType="/0/String"/>
ordered="false" lowerBound="1" eType="/1/Class"
eOpposite="/1/Class/feature"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Class"
eSuperTypes="/1/Classifier">
ordered="false" upperBound="-1" eType="/1/Feature" containment="true"
eOpposite="/1/Feature/classs"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Attribute"
eSuperTypes="/1/Feature"/>
<eClassifiers xsi:type="ecore:EClass" name="Parameter"
name="operationn" ordered="false" lowerBound="1" eType="/1/Operation"
eOpposite="/1/Operation/parameter"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Operation"
eSuperTypes="/1/Feature">
ordered="false" upperBound="-1" eType="/1/Parameter" containment="true"
eOpposite="/1/Parameter/operationn"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AssociationEnd"
<eStructuralFeatures xsi:type="ecore:EReference" name="otherEnd"
ordered="false" eType="/1/AssociationEnd"/>
name="association" ordered="false" lowerBound="1" eType="/1/Association"
eOpposite="/1/Association/end"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Association">
ordered="false" lowerBound="2" upperBound="-1" eType="/1/AssociationEnd"
eOpposite="/1/AssociationEnd/association"/>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
xmlns="UML">
</feature>
</feature>
</Class>
</Class>
</Class>
</Class>
</xmi:XMI>
FUDForum. Page generated in 0.03252 seconds
