How to un-install plugins? [message #206121] |
Thu, 19 April 2007 14:41 |
Originally posted by: www.nospam.net
I like to play all kinds of Eclipse plugins. Now, I hope to get rid of
some of plugins I have installed. I use Eclipse on Linux machine.
Normally, I install plugins through Eclispe Help->Software
Updates...->Find & Install..
I am wondering if there is also a safe way to un-install the plugin.
For example, I want to un-install Omndo EclipseUML
plugin(http://www.eclipsedownload.com/index.html). I have opened "View
Installation History" and see a lot of files being installed. I am not
sure which file goes with the plugin and needs to be deleted.
Thank you very much.
Re: How to un-install plugins? [message #206230 is a reply to message #206207] |
Thu, 19 April 2007 19:03 |
Steve Whatmore wrote:
> Go to Help>>Software Updates>>Manage Configuration
> Select the extension that you wish to uninstall, disable it and then
> uninstall from the right hand panel.
I have been the place (Help>>Software Updates>>Manage Configuration) and
disabled the plugins. Restart Eclipse. Two questions remain:
1)I don't see anything related to uninstall from the right hand panel. I
am using Eclipse 3.2.2.
2)The diabled plugin completely disappeared. They are not shown on the
left hand side. If I want them back, what should I do?
Re: How to un-install plugins? [message #206344 is a reply to message #206230] |
Fri, 20 April 2007 08:02 |
Originally posted by: jakub.jurkiewicz.gmail.com
To see all disabled plugins you have to select button "Show Disabled
Features", which is the third button from left on the bar under File.
I hope you get it right ;)
regards
Jakub Jurkiewicz
FUDForum. Page generated in 0.08184 seconds
