Home » Archived » Maven Integration (M2E) » [tycho] cannot run demo on 0.3.0-DEV-1819
[tycho] cannot run demo on 0.3.0-DEV-1819 [message #19845] Fri, 12 December 2008 18:19 Go to next message
When I run "mvn org.codehaus.tycho:maven-tycho-plugin:generate-poms" on
1819, I get this error:
[ERROR]
Cannot find mojo descriptor for:
'org.codehaus.tycho:maven-tycho-plugin:generate
-poms' - Treating as non-aggregator.
The same command works on 0.3.0-DEV-1719. Any tips?
Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #19918 is a reply to message #19845] Sat, 13 December 2008 11:05 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Will,
I just tried tycho demo script [1] on linux using 0.3.0-DEV-1819 and
everything worked as expected. What platform you are on? What is exact
command you used to generate pom.xml files? Can you rerun the command
with error stack traces enabled (-e parameter) and post output here?
As a side note, tycho needs really basic pom.xml files, so it should not
be too difficult to write them by hand. And even for generated pom.xml
files, I recommend keeping them as part of project source tree. This way
you will be able to customize your build when needed.
[1] http://docs.codehaus.org/display/M2ECLIPSE/Tycho+technology+ demo+script
Igor
> [ERROR]
Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #19942 is a reply to message #19918] Tue, 16 December 2008 19:49 Go to previous messageGo to next message
Thanks for investigating. I tried again (in the same shell, in fact!)
and it worked fine. So this must have been an issue with my
connectivity or a temporary blip in the repo.
This was on Windows Vista, by the way (full command and output from
before is below).
After generating the poms, I was able to successfully build a
feature-based version of the tycho demo (something I couldn't do in
1719). It is truly quite amazing to see this happening in maven and I am
really looking forward to maven 3.0. I am willing to document the
feature-based steps if that would be helpful to others.
-Will
c:\workspaces\tycho-demo>c:\tycho-distribution-0.3.0-DEV-1819\bin\mvn
org.codehaus.tycho:maven-tycho-plugin:generate-poms -DgroupId=tycho.demo
-Dtycho.targetPlatform=c:\eclipse\eclipse-3.4.1-rcp
[INFO] Build target platform
tycho.targetPlatform=c:\eclipse\eclipse-3.4.1-rcp. This overrides target
platform specified in pom.xml files, if any.
[ERROR]
'org.codehaus.tycho:maven-tycho-plugin:generate-poms' - Treating as
non-aggregator.
[INFO]
[INFO] For more information, run with the -e flag
[INFO]
[INFO] BUILD FAILED
[INFO]
[INFO] Total time: < 1 second
[INFO] Finished at: Fri Dec 12 15:16:38 PST 2008
[INFO] Final Memory: 3M/7M
[INFO]
Igor Fedorenko wrote:
> Will,
> Igor
>> on 1819, I get this error:
>> [ERROR]
Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #25197 is a reply to message #19942] Thu, 30 April 2009 07:57 Go to previous messageGo to next message
Hi Will and Igor,
I am facing similar problem in Linux. I tried to clean ~/.m2/repository
to verify that my proxy allows to upload necessary plug-ins. To me it
seems that I cannot upload only maven-tycho-plugin.
Could you help?
-Petr
here is my command/output:
mvn -e org.codehaus.tycho:maven-tycho-plugin:generate-poms
-DgroupId=tycho.demo -Dtycho.targetPlatform=/home/petr/ganymede/eclipse/
+ Error stacktraces are turned on.
[INFO] Attempting to resolve a version for plugin:
org.codehaus.tycho:maven-tycho-plugin using meta-version: LATEST
[INFO] Using version: LATEST of plugin:
[ERROR]
non-aggregator.
Error stacktrace:
org.apache.maven.InvalidTaskException: Cannot find mojo descriptor for:
non-aggregator.
org.apache.maven.lifecycle.TaskValidationResult.generateInva lidTaskException(TaskValidationResult.java:78)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:182)
at org.apache.maven.embedder.MavenEmbedder.execute(MavenEmbedde r.java:846)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:160)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:63)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:57)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
org.codehaus.plexus.classworlds.launcher.Launcher.launchEnha nced(Launcher.java:289)
org.codehaus.plexus.classworlds.launcher.Launcher.launch(Lau ncher.java:229)
org.codehaus.plexus.classworlds.launcher.Launcher.mainWithEx itCode(Launcher.java:408)
org.codehaus.plexus.classworlds.launcher.Launcher.main(Launc her.java:351)
Caused by: org.apache.maven.plugin.loader.PluginLoaderException: Failed
to load plugin. Reason: Plugin could not be found - check that the goal
name is correct: Unable to determine the latest version
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.codehaus.tycho
-DartifactId=maven-tycho-plugin -Dversion=LATEST
-Dpackaging=maven-plugin -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file
there:
mvn deploy:deploy-file -DgroupId=org.codehaus.tycho
-Dpackaging=maven-plugin -Dfile=/path/to/file -Durl=[url]
-DrepositoryId=[id]
org.codehaus.tycho:maven-tycho-plugin:maven-plugin:LATEST
org.apache.maven.plugin.loader.DefaultPluginLoader.loadPlugi n(DefaultPluginLoader.java:99)
org.apache.maven.plugin.loader.DefaultPluginLoader.loadPlugi n(DefaultPluginLoader.java:54)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.getMojoD escriptorForDirectInvocation(DefaultLifecycleExecutor.java:8 50)
org.apache.maven.lifecycle.DefaultLifecycleExecutor.isTaskVa lid(DefaultLifecycleExecutor.java:672)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:178)
... 11 more
Caused by: org.apache.maven.plugin.PluginNotFoundException: Plugin could
not be found - check that the goal name is correct: Unable to determine
the latest version
there:
-DrepositoryId=[id]
org.apache.maven.plugin.DefaultPluginManager.verifyVersioned Plugin(DefaultPluginManager.java:250)
org.apache.maven.plugin.DefaultPluginManager.verifyPlugin(De faultPluginManager.java:199)
org.apache.maven.plugin.loader.DefaultPluginLoader.loadPlugi n(DefaultPluginLoader.java:81)
... 15 more
[INFO]
[INFO] BUILD FAILED
[INFO]
> before is below).
> -Will
> [ERROR]
> non-aggregator.
> [INFO]
> [INFO]
> [INFO] BUILD FAILED
> [INFO]
> [INFO]
>> Will,
>> not be too difficult to write them by hand. And even for generated
>> pom.xml files, I recommend keeping them as part of project source
>> tree. This way you will be able to customize your build when needed.
>> [1]
>> Regards,
>> Igor
>>> [ERROR]
Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #25238 is a reply to message #25197] Thu, 30 April 2009 10:06 Go to previous messageGo to next message
Petr,
Can you confirm that you are using Tycho installation to run
generate-poms? Also, check M2_HOME environment variable. If set, it must
point to Tycho installation.
Also, we have a mailing list dedicated to Tycho. You can subscribe by
sending email to tycho-users-subscribe@lists.sonatype.com.
Igor
Petr Baranov wrote:
> Hi Will and Igor,
> Could you help?
> -Petr
> [ERROR]
> non-aggregator.
> Error stacktrace:
> non-aggregator.
> at
> at
> at
> at
> at
> at
> at
> at
> there:
> -DrepositoryId=[id]
> at
> at
> at
> at
> ... 11 more
> the latest version
> there:
> -DrepositoryId=[id]
> at
> at
> at
> ... 15 more
> [INFO]
> [INFO] BUILD FAILED
> [INFO]
>> before is below).
>> am really looking forward to maven 3.0. I am willing to document the
>> -Will
>> -DgroupId=tycho.demo -Dtycho.targetPlatform=c:\eclipse\eclipse-3.4.1-rcp
>> target platform specified in pom.xml files, if any.
>> [ERROR]
>> non-aggregator.
>> [INFO]
>> [INFO]
>> [INFO] BUILD FAILED
>> [INFO]
>> [INFO]
>>> Will,
>>> exact command you used to generate pom.xml files? Can you rerun the
>>> command with error stack traces enabled (-e parameter) and post
>>> output here?
>>> [1]
>>> Regards,
>>> Igor
>>>> [ERROR]
Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #25319 is a reply to message #25238] Thu, 07 May 2009 09:43 Go to previous messageGo to next message
Hi all,
trying to use 0.3.0-DEV-1819 back in February and now 0.4.0-DEV-2233
respectively, I had the very same problem. I still do not know the reason
why, but I suppose it has to do with our company firewall.
Once I installed Nexus (v1.3.3-gpl) and configured the tycho settings as
described in the nexus docs... BUILD SUCCESSFUL.
Note, that I have a 2.0.9 installation on the same machine, which never
had any problems getting dependencies from public repos.
Regards.
Joerg
Re: [tycho] cannot run demo on 0.3.0-DEV-1819 [message #25482 is a reply to message #25319] Thu, 07 May 2009 19:44 Go to previous message
This probably does not help much, but I believe there were issues with
mirror and proxy support in Maven 3.0-alpha-1 used in Tycho.
FYI, Maven codebase is changing very quickly right now, so we decided to
wait until things settle down a bit before updating Tycho.
Igor
Joerg Buchberger wrote:
> Hi all,
> reason why, but I suppose it has to do with our company firewall.
> Regards.
> Joerg
Previous Topic:M2Eclipse and Eclipse 3.4.2?
Next Topic:[tycho] best way of using multiple maven versions in parallel
Current Time: Sun Nov 09 00:06:51 EST 2025
Powered by FUDForum. Page generated in 0.04361 seconds
