Home » Modeling » GMF (Graphical Modeling Framework) » Body of getViewChildren exceeds 64K
Body of getViewChildren exceeds 64K [message #205952] Thu, 18 September 2008 07:16 Go to next message
I'm currently working with a fairly big metamodel consisting of around
160 different nodes and a few hundred references (which are mapped to
nodes and connections in the editor). When I generate the diagram code,
the body of the getViewChildren(View view, Object parentElement) in the
XXXNavigatorContentProvider class exceeds 64K and Eclipse complains
about that. Is this a known limitation? Any workarounds?
Dimitrios
Re: Body of getViewChildren exceeds 64K [message #205968 is a reply to message #205952] Thu, 18 September 2008 07:18 Go to previous messageGo to next message
In case it makes a difference, I'm using the version of GMF that ships
with the Ganymede Modeling distribution (2.1.0?)
Dimitrios Kolovos wrote:
> Cheers,
> Dimitrios
Re: Body of getViewChildren exceeds 64K [message #205990 is a reply to message #205952] Thu, 18 September 2008 07:24 Go to previous messageGo to next message
Hello Dimitrios,
Well, we have riched this limit several times in the past with other generated
classes.. ;-(
Can you please submitt bug report for it?
Concerning the workaround for now - you can modify this method splitting
it on two or more..
Alex Shatalin
Re: Body of getViewChildren exceeds 64K [message #205998 is a reply to message #205990] Thu, 18 September 2008 07:38 Go to previous message
Hi Alex,
Thanks for your prompt reply. This is indeed a quite common problem with
generators.
The bug report is here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=247810
Dimitrios
Alex Shatalin wrote:
> Hello Dimitrios,
> generated classes.. ;-(
> it on two or more..
> Alex Shatalin
Previous Topic:adding child figures causes bounds anomalies when zoomed out
Next Topic:Is it possible to use GMF on a abstract semantic model ?
Current Time: Sun Jul 13 18:18:24 EDT 2025
Powered by FUDForum. Page generated in 0.04549 seconds
