Connect RCP application to JBoss JNDI server errors. [message #205743] |
Thu, 04 March 2004 01:35  |
Originally posted by: scttu.hotmail.com
I get the class not found exception whenever i try to connect to JBoss JNDI
server from my RCP application. Can someone show me how to do it correctly.
Any helps are very much appreciated.
Stephen
private Context getContext() throws NamingException{
Context ctx = null;
try{
Properties props = new Properties();
props.setProperty(Context.PROVIDER_URL,"jnp://172.16.0.112:1099" );
props.setProperty(Context.INITIAL_CONTEXT_FACTORY,
"org.jnp.interfaces.NamingContextFactory");
props.setProperty(Context.URL_PKG_PREFIXES,"org.jboss.naming:org.jnp.interfa
ces");
ctx = new InitialContext(props);
}catch(NamingException e){
throw e;
return ctx;
in my plugin.xml descriptor file i have the following entry
<runtime>
<library name="sy-rcp.jar">
<export name="*"/>
</library>
<library name="lib/jbossall-client.jar/>
<library name="lib/jnp-client.jar">
<export name="*"/>
</library>
<library name="lib/commons-lang.jar"/>
<library name="lib/commons-beanutils.jar"/>
<library name="lib/commons-logging.jar"/>
<library name="lib/j2ee.jar"/>
</runtime>
javax.naming.NoInitialContextException: Cannot instantiate class:
org.jnp.interfaces.NamingContextFactory [Root exception is
java.lang.ClassNotFoundException: org.jnp.interfaces.NamingContextFactory]
at javax.naming.spi.NamingManager.getInitialContext(Unknown Source)
at javax.naming.InitialContext.getDefaultInitCtx(Unknown Source)
at javax.naming.InitialContext.init(Unknown Source)
at javax.naming.InitialContext.<init>(Unknown Source)
my.com.shinyang.ui.views.LogReceivingSearchView.getContext(L ogReceivingSearc
hView.java:111)
my.com.shinyang.ui.views.LogReceivingSearchView.access$0(Log ReceivingSearchV
iew.java:100)
my.com.shinyang.ui.views.LogReceivingSearchView$2.run(LogRec eivingSearchView
..java:64)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.ui.actions.RetargetAction.runWithEvent(RetargetA ction.java:212)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:490)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContribu
tionItem.java:462)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2029)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
at my.com.shinyang.ui.MainWindow.run(MainWindow.java:26)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Caused by: java.lang.ClassNotFoundException:
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
at com.sun.naming.internal.VersionHelper12.loadClass(Unknown Source)
.... 30 more
Re: Connect RCP application to JBoss JNDI server errors. [message #206522 is a reply to message #205743] |
Fri, 05 March 2004 08:57  |
Originally posted by: ifedorenko.rogers.com
Stephen,
Set thread context classloader to your plugin classloader using
something like:
ClassLoader orig = Thread.currentThread().getContextClassLoader();
try {
Thread.currentThread().setConextClassLoader(YourPlugin.class .getCLassLoader());
... do your JDNI things here
} finally
Thread.currentThread().setConextClassLoader(orig);
> Thanks
> Stephen
> Context ctx = null;
> try{
> ces");
> throw e;
> return ctx;
> <runtime>
> <export name="*"/>
> </library>
> <export name="*"/>
> </library>
> </runtime>
> at
> hView.java:111)
> at
> iew.java:100)
> at
> .java:64)
> at
> at
> at
> tem.java:490)
> at
> tionItem.java:462)
> at
> at
> java:257)
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 30 more
FUDForum. Page generated in 0.03589 seconds
