Home » Language IDEs » ServerTools (WTP) » Re-deploying tomcat 5.5
Re-deploying tomcat 5.5 [message #205646] Wed, 12 December 2007 11:49 Go to next message
Originally posted by: ranavishal.gmail.com
Hello All,
Just a quick question:
Do I need to restart the server everytime I make changes in web.xml, java
file or any other configuration file like struts-config.xml
Development Env.
Eclipse wtp 2.0.1
Tomcat 5.5
PS: Tomcat configured inside the eclipse
Vishal
Re: Re-deploying tomcat 5.5 [message #205653 is a reply to message #205646] Wed, 12 December 2007 12:28 Go to previous messageGo to next message
Vishal Rana wrote:
> Hello All,
> java file or any other configuration file like struts-config.xml
> Development Env.
> Eclipse wtp 2.0.1
> Tomcat 5.5
> Thanks
> Vishal
For these kinds of files, when the change is published to the Tomcat
server, if the change triggers a context reload, then you can probably
skip the restart. However, it is fairly typical for the old context to
"leak" and not be fully garbage collected. After some number of
reloads, the server may run out of memory and restart will be needed to
clean things up.
Larry
Re: Re-deploying tomcat 5.5 [message #205677 is a reply to message #205653] Wed, 12 December 2007 13:35 Go to previous messageGo to next message
Thanks, do we have any option to redeploy the application right from the
eclipse?
Re: Re-deploying tomcat 5.5 [message #205685 is a reply to message #205677] Wed, 12 December 2007 14:23 Go to previous messageGo to next message
> eclipse?
I'm not sure exactly what you mean by "redeploy". If you mean force a
context reload, the answer is no. The Tomcat support in WTP currently
doesn't support control of the Tomcat server beyond starting and
stopping and what "control" can be accomplished via the configuration files.
Larry
Re: Re-deploying tomcat 5.5 [message #205692 is a reply to message #205685] Wed, 12 December 2007 14:31 Go to previous messageGo to next message
Thanks for your help :)
Re: Re-deploying tomcat 5.5 [message #205717 is a reply to message #205685] Thu, 13 December 2007 07:21 Go to previous messageGo to next message
Larry Isaacs wrote:
>> the eclipse?
> files.
> Cheers,
> Larry
Not exactly sure this is a *good* answer to this question, but I have
also been struggling with this lack of control, so I have for mature
projects switched to a pure Java project with a setup where classes are
created as required by Tomcat and and in the
apache-tomcat-6.0.14\conf\Catalina\localhost directory I have created a
file which contains:
<Context docBase="C:/eclipse_projects/MyApp/web" reloadable="true"/>
This works fine for the reload scenario and for session (and other)
control I use the admin app.
This of course excludes me from all nice WTP features but give me more
control over my TomCat apps.
:) Goran Rehnlund
Re: Re-deploying tomcat 5.5 [message #205725 is a reply to message #205717] Thu, 13 December 2007 08:16 Go to previous message
Originally posted by: wojtekmichalik.softtellco.com.pl
<path id="master-classpath">
<fileset dir="${web.dir}/WEB-INF/lib">
<include name="*.jar"/>
</fileset>
<!-- We need the servlet API classes: -->
<!-- for Tomcat 4.1 use servlet.jar -->
<!-- for Tomcat 5.0 use servlet-api.jar -->
<!-- for Other app server - check the docs -->
<fileset dir="${appserver.home}/common/lib">
<include name="servlet*.jar"/>
</fileset>
<pathelement path="${build.dir}"/>
</path>
<target name="usage">
<echo message=""/>
<echo message="${name} build file"/>
<echo message="-----------------------------------"/>
<echo message=""/>
<echo message="Available targets are:"/>
<echo message=""/>
<echo message="build --> Build the application"/>
<echo message="deploy --> Deploy application as directory"/>
<echo message="deploywar --> Deploy application as a WAR file"/>
<echo message="install --> Install application in Tomcat"/>
<echo message="reload --> Reload application in Tomcat"/>
<echo message="start --> Start Tomcat application"/>
<echo message="stop --> Stop Tomcat application"/>
<echo message="list --> List Tomcat applications"/>
<echo message=""/>
</target>
<target name="build" description="Compile main source tree java
files">
<mkdir dir="${build.dir}"/>
<javac destdir="${build.dir}" target="1.3" debug="true"
deprecation="false" optimize="false" failonerror="true">
<src path="${src.dir}"/>
<classpath refid="master-classpath"/>
</javac>
</target>
<target name="deploy" depends="build" description="Deploy
application">
<copy todir="${deploy.path}/${name}" preservelastmodified="true">
<fileset dir="${web.dir}">
<include name="**/*.*"/>
</fileset>
</copy>
</target>
<target name="deploywar" depends="build" description="Deploy
application as a WAR file">
<war destfile="${name}.war"
webxml="${web.dir}/WEB-INF/web.xml">
</fileset>
</war>
<copy todir="${deploy.path}" preservelastmodified="true">
<fileset dir=".">
<include name="*.war"/>
</fileset>
</copy>
</target>
<!-- Tomcat tasks - remove these if you don't have Tomcat installed -->
<taskdef name="install"
classname="org.apache.catalina.ant.InstallTask">
<classpath>
<path location="${appserver.home}/server/lib/catalina-
ant.jar"/>
</classpath>
</taskdef>
<taskdef name="reload" classname="org.apache.catalina.ant.ReloadTask">
<classpath>
ant.jar"/>
</classpath>
</taskdef>
<taskdef name="list" classname="org.apache.catalina.ant.ListTask">
<classpath>
ant.jar"/>
</classpath>
</taskdef>
<taskdef name="start" classname="org.apache.catalina.ant.StartTask">
<classpath>
ant.jar"/>
</classpath>
</taskdef>
<taskdef name="stop" classname="org.apache.catalina.ant.StopTask">
<classpath>
ant.jar"/>
</classpath>
</taskdef>
<target name="install" description="Install application in Tomcat">
<install url="${tomcat.manager.url}"
username="${tomcat.manager.username}"
password="${tomcat.manager.password}"
path="/${name}"
war="${name}"/>
</target>
<target name="reload" description="Reload application in Tomcat">
<reload url="${tomcat.manager.url}"
path="/${name}"/>
</target>
<target name="start" description="Start Tomcat application">
<start url="${tomcat.manager.url}"
path="/${name}"/>
</target>
<target name="stop" description="Stop Tomcat application">
<stop url="${tomcat.manager.url}"
path="/${name}"/>
</target>
<target name="list" description="List Tomcat applications">
<list url="${tomcat.manager.url}"
password="${tomcat.manager.password}"/>
</target>
Previous Topic:edit HTML file
Next Topic:Tag File Validation Bugs?
Current Time: Tue Jul 15 06:51:43 EDT 2025
Powered by FUDForum. Page generated in 0.03520 seconds
