reading System properties [message #205628] |
Wed, 17 September 2008 06:33  |
I need to read system properties, e.g.
com.sun.xml.namespace.QName.useCompatibleSerialVersionUID=1. 0, from a file.
It works fine independently, but I have troubles with incorporating this
functionality into RCP application.
I call the function I wrote for reading from Application::start(). As a
result I get an exception and the application terminates.
I need to set this property for the whole app.
I will apprciate your advice.
best,
mr.woolf.
Re: reading System properties [message #205693 is a reply to message #205674] |
Wed, 17 September 2008 07:49  |
Nagesh,
first of all, thank you for the rapid reply. Your suggestion sounds
interesting.
Althoug, I need to clarify certain things.
1. I need to store those values in a file that we can ship it with a
product and change w/o re-building a whole project.\
2. My main concern here is that I need to find a certain entry point into
Eclipse RCP application where I can read those properties, set them by
sending request to System.setProperties() and this should not terminate an
application as it happens in teh example I mentioned earlier in the
original post.
Thank you in advance!
FUDForum. Page generated in 0.04007 seconds
