library version clash (two versions of the same library) [message #205573] |
Tue, 17 April 2007 20:17 |
Originally posted by: subscription_REMOVE_101.hot_REMOVE_mail.com
My Eclipse project uses JUnit 3.8.1 for unit testing. Recently, I have
added commons-cli from apache to my project, which (through Maven2) requires
JUnit 3.7 . Now all my other tests want to use 3.7 instead, so the tests
break. Is there a way to force my tests to use the proper version?
One "issue" is the fact that I have my project managed with Maven2, which
causes 3.7 to be included into my build path of Eclipse because of the pom
that comes with common-cli. This is not a problem when I use mvn to build.
Thanks for the help,
Martijn
http://www.sereneconcepts.nl
FUDForum. Page generated in 0.07442 seconds
