Home » Eclipse Projects » DSDP - Target Management » Incompatible Host Server Error
Incompatible Host Server Error [message #19745] Sat, 29 March 2008 17:15 Go to next message
Hi All,
I'm working with RSE for the first time, and in trying to get the RSE
server up and running on my (Linux) server, I get a Incompatible Host
Server error when I try to connect from Eclipse. I have JRE "1.6.0_05"
installed, a hole in the firewall, and the proper listening ports
configured for connection.
I've tried running the 3.0 version, (up from the previous stable
release) but get the same error.
Any insights?
Thanks.
Re: Incompatible Host Server Error [message #19983 is a reply to message #19745] Mon, 31 March 2008 11:09 Go to previous messageGo to next message
Hi Asai,
Could you tell me how you're running the Linux server? Are you running a
daemon (via daemon.pl) or are you using the server directly? Could you show
me the shell output that the server produces?
Dave
"Asai" <asai@globalchangemusic.org> wrote in message
news:fsmbho$1ga$1@build.eclipse.org...
> Hi All,
> I've tried running the 3.0 version, (up from the previous stable release)
> Any insights?
> Thanks.
Re: Incompatible Host Server Error [message #20062 is a reply to message #19983] Mon, 31 March 2008 11:22 Go to previous messageGo to next message
Also, could you please file a bug for this. I find bugzilla
better to search and archive than the newsgroup.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%2 0Management&version=unspecified&component=RSE
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
David McKnight wrote:
> Hi Asai,
> Dave
>> Hi All,
>> Any insights?
>> Thanks.
Re: Incompatible Host Server Error [message #20092 is a reply to message #19983] Mon, 31 March 2008 11:32 Go to previous messageGo to next message
Hi, David,
Thanks so much for your reply.
Here's the linux command line and the output:
[root@foo rseserver]# ./daemon.pl 4075 10001-10010
Daemon running on: foo.bar.net, port: 4075
launched new server on 10001
RECEIVER ERROR
java.lang.Exception: The connection to the server has been lost.
finished on port 10001
> Hi Asai,
> Dave
>> Hi All,
>> Any insights?
>> Thanks.
Re: Incompatible Host Server Error [message #20503 is a reply to message #20092] Mon, 31 March 2008 12:22 Go to previous messageGo to next message
Hi Asai,
I have not tried running the server with JRE 1.6 before. Does it make any
difference for you when using JRE 1.5 or 1.4?
news:fsr06q$aqs$1@build.eclipse.org...
> Hi, David,
> RECEIVER ERROR
>> Hi Asai,
>> show me the shell output that the server produces?
>> Thanks,
>> Dave
>>> Hi All,
>>> Any insights?
>>> Thanks.
Re: Incompatible Host Server Error [message #20509 is a reply to message #20062] Mon, 31 March 2008 12:23 Go to previous messageGo to next message
I have submitted this in the bugzilla tracker.
> Cheers,
>> Hi Asai,
>> running a daemon (via daemon.pl) or are you using the server
>> directly? Could you show me the shell output that the server produces?
>> Thanks,
>> Dave
>>> Hi All,
>>> "1.6.0_05" installed, a hole in the firewall, and the proper
>>> listening ports configured for connection.
>>> Any insights?
>>> Thanks.
Re: Incompatible Host Server Error [message #20518 is a reply to message #20503] Mon, 31 March 2008 12:41 Go to previous messageGo to next message
I will try this and let you know. Thanks.
> Hi Asai,
>> Hi, David,
>> RECEIVER ERROR
>>> Hi Asai,
>>> Thanks,
>>> Dave
>>>> Hi All,
>>>> Any insights?
>>>> Thanks.
Re: Incompatible Host Server Error [message #20526 is a reply to message #20503] Mon, 31 March 2008 13:08 Go to previous messageGo to next message
Hi David,
I uninstalled ver 1.6 and put in 1.5, but still no dice. Same error.
> Hi Asai,
>> Hi, David,
>> RECEIVER ERROR
>>> Hi Asai,
>>> Thanks,
>>> Dave
>>>> Hi All,
>>>> Any insights?
>>>> Thanks.
Re: Incompatible Host Server Error [message #20535 is a reply to message #20526] Mon, 31 March 2008 13:21 Go to previous messageGo to next message
Hi Asai,
Hmm.. I haven't seen this before.
As an experiment, could you try connecting to the server directly?
Steps:
1) start the server directly using server.sh
2) In RSE, go to the Server Launcher Settings property page for the file
subsystem and specify connect to running server.
3) On the Subsystem property page specify the port that the server you
started is running on.
news:fsr5qa$fto$1@build.eclipse.org...
> Hi David,
>> Hi Asai,
>> any difference for you when using JRE 1.5 or 1.4?
>>> Hi, David,
>>> RECEIVER ERROR
>>>> Hi Asai,
>>>> a daemon (via daemon.pl) or are you using the server directly? Could
>>>> Thanks,
>>>> Dave
>>>>> Hi All,
>>>>> "1.6.0_05" installed, a hole in the firewall, and the proper listening
>>>>> Any insights?
>>>>> Thanks.
Re: Incompatible Host Server Error [message #20545 is a reply to message #20535] Mon, 31 March 2008 13:36 Go to previous messageGo to next message
Sure,
here's the result:
[root@foo rseserver]# ./server.pl
DStore Server Starting...
Server Started Successfully
4033
Server running on: foo.bar.net
RECEIVER ERROR
org.eclipse.dstore.internal.core.util.XMLparser.readLine(XML parser.java:363)
org.eclipse.dstore.internal.core.util.XMLparser.parseDocumen t(XMLparser.java:480)
org.eclipse.dstore.internal.core.util.Receiver.handleInput(R eceiver.java:117)
org.eclipse.dstore.internal.core.util.Receiver.run(Receiver. java:98)
Server Finished
> Hi Asai,
> Steps:
>> Hi David,
>>> Hi Asai,
>>>> Hi, David,
>>>> RECEIVER ERROR
>>>>> Hi Asai,
>>>>> Thanks,
>>>>> Dave
>>>>>> Hi All,
>>>>>> Any insights?
>>>>>> Thanks.
Re: Incompatible Host Server Error [message #20555 is a reply to message #20545] Mon, 31 March 2008 13:49 Go to previous message
Okay, discussion of this will continue in:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=224934
news:fsr7fm$ue8$1@build.eclipse.org...
> Sure,
> here's the result:
> 4033
> RECEIVER ERROR
> at
> at
> at
> at
> Server Finished
>> Hi Asai,
>> Steps:
>> Thanks,
>>> Hi David,
>>>> Hi Asai,
>>>>> Hi, David,
>>>>> RECEIVER ERROR
>>>>>> Hi Asai,
>>>>>> produces?
>>>>>> Thanks,
>>>>>> Dave
>>>>>>> Hi All,
>>>>>>> RSE server up and running on my (Linux) server, I get a Incompatible
>>>>>>> Host Server error when I try to connect from Eclipse. I have JRE
>>>>>>> Any insights?
>>>>>>> Thanks.
Re: Incompatible Host Server Error [message #573245 is a reply to message #19745] Mon, 31 March 2008 11:09 Go to previous message
Hi Asai,
Dave
> Hi All,
> Any insights?
> Thanks.
Re: Incompatible Host Server Error [message #573288 is a reply to message #19983] Mon, 31 March 2008 11:22 Go to previous message
> Hi Asai,
> Dave
>> Hi All,
>> Any insights?
>> Thanks.
Re: Incompatible Host Server Error [message #573318 is a reply to message #19983] Mon, 31 March 2008 11:32 Go to previous message
Hi, David,
RECEIVER ERROR
> Hi Asai,
> Dave
>> Hi All,
>> Any insights?
>> Thanks.
Re: Incompatible Host Server Error [message #573382 is a reply to message #20092] Mon, 31 March 2008 12:22 Go to previous message
Hi Asai,
> Hi, David,
> RECEIVER ERROR
>> Hi Asai,
>> Thanks,
>> Dave
>>> Hi All,
>>> Any insights?
>>> Thanks.
Re: Incompatible Host Server Error [message #573399 is a reply to message #20062] Mon, 31 March 2008 12:23 Go to previous message
> Cheers,
>> Hi Asai,
>> Thanks,
>> Dave
>>> Hi All,
>>> Any insights?
>>> Thanks.
Re: Incompatible Host Server Error [message #573429 is a reply to message #20503] Mon, 31 March 2008 12:41 Go to previous message
> Hi Asai,
>> Hi, David,
>> RECEIVER ERROR
>>> Hi Asai,
>>> Thanks,
>>> Dave
>>>> Hi All,
>>>> Any insights?
>>>> Thanks.
Re: Incompatible Host Server Error [message #573444 is a reply to message #20503] Mon, 31 March 2008 13:08 Go to previous message
Hi David,
> Hi Asai,
>> Hi, David,
>> RECEIVER ERROR
>>> Hi Asai,
>>> Thanks,
>>> Dave
>>>> Hi All,
>>>> Any insights?
>>>> Thanks.
Re: Incompatible Host Server Error [message #573470 is a reply to message #20526] Mon, 31 March 2008 13:21 Go to previous message
Hi Asai,
Steps:
> Hi David,
>> Hi Asai,
>>> Hi, David,
>>> RECEIVER ERROR
>>>> Hi Asai,
>>>> Thanks,
>>>> Dave
>>>>> Hi All,
>>>>> Any insights?
>>>>> Thanks.
Re: Incompatible Host Server Error [message #573497 is a reply to message #20535] Mon, 31 March 2008 13:36 Go to previous message
Sure,
here's the result:
4033
RECEIVER ERROR
Server Finished
> Hi Asai,
> Steps:
>> Hi David,
>>> Hi Asai,
>>>> Hi, David,
>>>> RECEIVER ERROR
>>>>> Hi Asai,
>>>>> Thanks,
>>>>> Dave
>>>>>> Hi All,
>>>>>> Any insights?
>>>>>> Thanks.
Re: Incompatible Host Server Error [message #573518 is a reply to message #20545] Mon, 31 March 2008 13:49 Go to previous message
> Sure,
> here's the result:
> 4033
> RECEIVER ERROR
> at
> at
> at
> at
> Server Finished
>> Hi Asai,
>> Steps:
>> Thanks,
>>> Hi David,
>>>> Hi Asai,
>>>>> Hi, David,
>>>>> RECEIVER ERROR
>>>>>> Hi Asai,
>>>>>> produces?
>>>>>> Thanks,
>>>>>> Dave
>>>>>>> Hi All,
>>>>>>> Any insights?
>>>>>>> Thanks.
Previous Topic:how to filter out the appearance of context menu over RSE's remote system view
Next Topic:Questions about remote execution
Current Time: Fri Jul 18 01:47:36 EDT 2025
Powered by FUDForum. Page generated in 0.34016 seconds
