[PDE/Build] Exporting a product with plugins needing bytecode-enhancement [message #205389] |
Wed, 01 June 2005 05:32  |
Originally posted by: joerg.von.frantzius.artnology.nospam.com
currently we are developing an RCP application containing a plugin that
needs bytecode-enhancement. This is normal with the use of JDO and
possibly EJB 3.0 variants (?) and whatever the two will be merged into.
There are probably more technologies that apply bytecode-enhancement in
the build process, maybe e.g. AspectJ, if I understood it correctly from
a quick glance.
While building the project in the workspace everything works fine, as
there exists an Eclipse builder plugin.
However, exporting the set of plugins as a product is causing problems.
PDE automatically generates individual build.xml files for compiling and
packaging the plugins which are normally regenerated with every build.
An individual plugin's Build Configuration can be marked as being a
"Custom Build", causing PDE to keep the plugin's build.xml file instead
of overwriting it with every build. This enables us to place our
invocation of the JDO bytecode-enhancer between compiling and packaging
the jar of this plugin.
While it is nice that this is possible at all, this causes a bunch of
other problems. The build.xml contains absolute paths pointing to the
Eclipse installation directory of the machine where it was generated, so
it won't work on other machines (with a different Eclipse installation
directory), and it won't work with a newer Eclipse install on the same
machine.
It would be nice if the build configuration would cater for any
bytecode-enhancement needed for the plugin. Currently, we have made two
insertions in the build.xml: one for the invocation of the
enhancer-task, and a <path> specifiying the classpath to be used by the
enhancer. As a simplistic first idea, that would mean two text fields in
the configuration page the text of which would have to be inserted in
two different places in the build.xml
In case you experience similar problems, please feel free to vote for
bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=90514
RCP product export should invoke project builders [message #212722 is a reply to message #205389] |
Wed, 17 August 2005 06:56  |
For anyone using custom builders on their RCP products, e.g. for
bytecode-enhancing, this is the right bug to vote for:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104156
It is asking for the build process of RCP product export to invoke the
custom builders of the plugin-projects affected.
Joerg von Frantzius schrieb:
> that needs bytecode-enhancement. This is normal with the use of JDO
> and possibly EJB 3.0 variants (?) and whatever the two will be merged
> into. There are probably more technologies that apply
> bytecode-enhancement in the build process, maybe e.g. AspectJ, if I
> understood it correctly from a quick glance.
> problems. PDE automatically generates individual build.xml files for
> compiling and packaging the plugins which are normally regenerated
> with every build. An individual plugin's Build Configuration can be
> marked as being a "Custom Build", causing PDE to keep the plugin's
> build.xml file instead of overwriting it with every build. This
> enables us to place our invocation of the JDO bytecode-enhancer
> between compiling and packaging the jar of this plugin.
> so it won't work on other machines (with a different Eclipse
> installation directory), and it won't work with a newer Eclipse
> install on the same machine.
> two insertions in the build.xml: one for the invocation of the
> the enhancer. As a simplistic first idea, that would mean two text
> fields in the configuration page the text of which would have to be
> inserted in two different places in the build.xml
FUDForum. Page generated in 0.04011 seconds
