Home » Eclipse Projects » Babel » Problem after installing language pack for Eclipse Europa
Problem after installing language pack for Eclipse Europa [message #19716] Tue, 16 September 2008 12:18 Go to next message
I had installed the Language pack for Eclipse Europa (3.3.2) through
the update site
http://download.eclipse.org/technology/babel/update-site/eur opa
But after that I have quite a few problems. Please let me know if you have
encountered similar problems or anything wrong am I doing.
1. It some times shows up & some times doesn't show, the new language
packages info. in the product configuration.
2. When the info. doesn't come up, then there happens some serious problem
in the JRE, like we couldn't able to open the JRE dialog, it throws the
exception as below with some compilation error in the code.
Plug-in org.eclipse.jdt.debug.ui was unable to load class
org.eclipse.jdt.internal.debug.ui.jres.JREContainerWizardPag e.
An error occurred while automatically activating bundle
org.eclipse.jdt.debug.ui (85).
3. When I start eclipse with other languages (like French), some workbench
menus still come in English.
So any help/hint to the the solution of this problems is highly
appriceated & thanks in advance.
Re: Problem after installing language pack for Eclipse Europa [message #19772 is a reply to message #19716] Fri, 19 September 2008 10:38 Go to previous message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
Comments below...
chaitanya tangudu wrote:
> the update site
> have encountered similar problems or anything wrong am I doing.
Is there a reproduceable pattern? When I install a language pack and
launch Eclipse with the -nl option, it always shows up.
> problem in the JRE, like we couldn't able to open the JRE dialog, it
> throws the exception as below with some compilation error in the code.
There could be a bad translation somewhere, but without the full stack
it's hard to tell.
> workbench menus still come in English.
The translations are a community effort, and they are not complete
(yet). You can help out by logging into the Babel server and
translating those strings: http://babel.eclipse.org/
Thanks!
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
Re: Problem after installing language pack for Eclipse Europa [message #573786 is a reply to message #19716] Fri, 19 September 2008 10:38 Go to previous message
Comments below...
> the update site
it's hard to tell.
Thanks!
Previous Topic:Problem after installing language pack for Eclipse Europa
Next Topic:Carriage return characters
Current Time: Thu Jul 17 20:05:09 EDT 2025
Powered by FUDForum. Page generated in 0.07056 seconds
