Home » Language IDEs » ServerTools (WTP) » How do you share libs between developers?
How do you share libs between developers? [message #204994] Tue, 27 November 2007 08:30 Go to next message
Originally posted by: dserodio.gmail.com
I've posted a similar question here before, but the focus was different.
Our projects use some libs (like Spring and Hibernate), for which I'd
like to have the source code linked so I can browse their Javadocs,
improve code assist, etc.
1) If I use "User Libraries" for these libs, each developer will have to
separately download the libraries, unzip to their machines, etc, and
configure their Eclipse to point to them.
2) If I copy the jars to the project's "lib" directory (or WEB-INF/lib,
or similar), the developers don't have to download the libs to make the
project compile, but they won't have access to the lib's sources.
Is there a "mixed" approach, with the best of both choices (having the
Javadocs but not needing to download libs separately) ?
Maven is out of question, I'm currently using it but it causes more
trouble then it's worth.
Thanks in advance,
Daniel Serodio
Re: How do you share libs between developers? [message #205022 is a reply to message #204994] Tue, 27 November 2007 11:09 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Well... You can use the WEB-INF/lib approach and then associate javadoc
with entries under Web App Libraries as you would for User Libraries.
Each user will have to do the javadoc association individually since
that setting is stored in workspace metadata that you cannot share.
- Konstantin
Re: How do you share libs between developers? [message #205354 is a reply to message #205022] Mon, 03 December 2007 14:11 Go to previous message
Thanks, I thought that setting was stored in .classpath
Daniel Serodio
Previous Topic:Re: java editor - pause typing causes current word to be selected - continue then overtypes
Next Topic:Able to export to ear , cant publish to server ?
Current Time: Mon Jul 21 22:07:27 EDT 2025
Powered by FUDForum. Page generated in 0.07381 seconds
