Home » Newcomers » Newcomers » Error starting Eclipse on Debian 4 Etch
Error starting Eclipse on Debian 4 Etch [message #204946] |
Sun, 15 April 2007 08:04 |
Originally posted by: huubvanniekerk.gmail.com
The other day I installed Eclipse (from eclipse.org, not the Debian
version), together with the newest Sun JDK 1.6. After unpacking (tar
zxf) it into /opt, chown-ing /opt/eclipse to user and creating a
launcher for the desktop, the start ends in error. I do see the
Eclipse-logo, but before the loading-bar appears, it crashes with a
message about the logfile. After starting Eclipse in terminal, the error
says that /opt/eclipse/configuration is missing, which turns out to be
correct. I downloaded eclipse again, removed /opt/eclipse, unpacked and
chown-ed again, but same happens.
Checking the installation on FC6, I find that everything is there, and I
installed that (soon after the release of 3.2.2) without a problem.
Can someone give an explanation?
Huub
Re: Error starting Eclipse on Debian 4 Etch [message #204968 is a reply to message #204946] |
Sun, 15 April 2007 10:45 |
Originally posted by: haoniukun.gmail.com
I'm also using Eclipse on Debian Etch edition.
How about try to install eclipse from the kernel.org mirror and upgrade
your eclipse.
Wish you good luck.
Huub wrote:
> Huub
Re: Error starting Eclipse on Debian 4 Etch [message #204980 is a reply to message #204968] |
Sun, 15 April 2007 12:00 |
> your eclipse.
I'm not sure what you mean with kernel.org mirror. In the eclipse
mirrorlist I can't find that mirror.
Re: Error starting Eclipse on Debian 4 Etch [message #205003 is a reply to message #204946] |
Sun, 15 April 2007 15:20 |
Originally posted by: irbull.cs.uvic.ca
Hi Huub,
I have been running Eclipse on Debian Etch for years without a problem.
The one difference between our setup is that I don't install it in
/opt. I know you are chown-ing it to user, but try to unpack it
directly in your home directory. tar xvzf eclipse...tar in /home/<user>.
Then try to launch it. (cd eclipse; ./eclipse). I think the
configuration file is created on launch, so it sounds like there is a
problem creating it. If this works, then we can try and figure out why
you can't get it installed in opt. If this doesn't work, then there may
be a problem with your vm.
Let me know how it goes.
cheers,
ian
Huub wrote:
> Huub
Re: Error starting Eclipse on Debian 4 Etch [message #205024 is a reply to message #205003] |
Sun, 15 April 2007 15:50 |
Ian Bull wrote:
> Hi Huub,
> cheers,
> ian
Hi Ian,
After unpacking in ~/, it started ok. Then I removed /opt/eclipse,
recreated it with mkdir, chown-ed it to user, then with mc copied the
contents of ~/eclipse to /opt/eclipse. Now it does work ok. I still find
it odd that it refused to start the original way.
Huub
Re: Error starting Eclipse on Debian 4 Etch [message #205410 is a reply to message #204980] |
Tue, 17 April 2007 10:44 |
Just the apt source list.
Have you ever used apt?
>> your eclipse.
Current Time: Fri Apr 26 17:16:47 GMT 2024
Powered by FUDForum. Page generated in 0.08536 seconds
