ATL metamodel: conceptual question [message #19688] |
Wed, 28 February 2007 09:30  |
Originally posted by: kehrer.hdm-stuttgart.de
In the ATL metamodel, in- and out-models are of type OCLModel. OCLModels
conform to a metamodel, which is itself a OCLModel.
In the ATL user manual however, metamodels (e.g. MMAuthor oder MMPerson,
section 2.2 of the User Manual) are instances of the Ecore-metametamodel.
Now, why does the atl metamodel introduce the term OCLModel?
Isn't this a conflict?
thanks for any hints and ideas
Timo Kehrer
Re: ATL metamodel: conceptual question [message #20475 is a reply to message #19688] |
Fri, 02 March 2007 07:58  |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
The MMAuthor and MMPerson metamodels from the ATL user manual conform to the Ecore
metametamodel.
The OCLModel elements from the ATL metamodel are generic elements that are used as
"wrappers" to write expressions that refers to the models and metamodels in an ATL
transformation.
For instance, when you write MMAuthor!Author in an ATL transformation, the "MMAuthor"
token corresponds to an OCLModel element in the ATL model.
It is in the moment of execution of the ATL transformation that the ATL engine evaluates
this expression, and then accesses the "real" model and model elements (e.g., it matches a
MMAuthor!Author).
Marcos.
Timo Kehrer wrote:
> Hello,
> Timo Kehrer
FUDForum. Page generated in 0.03082 seconds
