Eclipse C++ Help T_T [message #204834] |
Sat, 14 April 2007 12:53 |
Originally posted by: classic_phone.hotmail.com
Hi, im new to eclipse. i need to install C++ plugin to eclipse. the
problem come with the compiler. should i opt for MingW or Cygwin? i used
both actually but still some problems appear. as for Cygwin, i install all
the needed package (in actual fact, i install all the stated in DEVEL) but
still i cant compile my hello world. any advice?
Re: Eclipse C++ Help T_T [message #204842 is a reply to message #204834] |
Sat, 14 April 2007 13:37 |
Originally posted by: haoniukun.gmail.com
What does the error message look like?
> all the needed package (in actual fact, i install all the stated in
> DEVEL) but still i cant compile my hello world. any advice?
Re: Eclipse C++ Help T_T [message #204849 is a reply to message #204842] |
Sat, 14 April 2007 15:54 |
thanks for ur attention
the error message goes like:
**** Build of configuration Debug for project lucky ****
c:\cygwin\bin\make.exe all
Building file: ../Lucky.cpp
Invoking: GCC C++ Compiler
c:\cygwin\bin\i686-pc-cygwin-g++.exe -O0 -g3 -Wall -c -fmessage-length=0
-MMD -MP -MF"Lucky.d" -MT"Lucky.d" -o"Lucky.o" "../Lucky.cpp"
/bin/sh: c:cygwinbini686-pc-cygwin-g++.exe: command not found
make: *** [Lucky.o] Error 127
Build complete for project lucky
i tin i miz some steps in installing compiler. izzit?
Re: Eclipse C++ Help T_T [message #204909 is a reply to message #204849] |
Sun, 15 April 2007 03:21 |
You didn't install cygwin's g++?
> c:\cygwin\bin\make.exe all Building file: ../Lucky.cpp
Re: Eclipse C++ Help T_T [message #204916 is a reply to message #204909] |
Sun, 15 April 2007 04:48 |
i did install. i install all those listed under DEVEL. but after those
finished, they are not automatically added into the c:\cygwin\bin. so i
extract the file in bin of the g++ core folder (which i installed) and
paste into the c:\cygwin\bin. so now i gvv -v and make -v in cmd, they
are recognized. but cannot compile file in eclipse. so how?
Re: Eclipse C++ Help T_T [message #204932 is a reply to message #204916] |
Sun, 15 April 2007 04:14 |
Did you run eclipse from cygwin's cmd window?
Re: Eclipse C++ Help T_T [message #204954 is a reply to message #204932] |
Sun, 15 April 2007 09:17 |
yes i tried tis is wat i get:
$ gcc koko.cpp
gcc: installation problem, cannot exec 'cc1plus': No such file or directory
Re: Eclipse C++ Help T_T [message #204962 is a reply to message #204954] |
Sun, 15 April 2007 08:56 |
It seems that you missed something.
You'd better try a cygwin maillist for that problem.:(
> $ gcc koko.cpp
FUDForum. Page generated in 0.09134 seconds
