Home » Archived » Maven Integration (M2E) » supported Maven plugin configuration parameters
supported Maven plugin configuration parameters [message #19667] Mon, 24 November 2008 21:22
In case if you are not watching changes on the project wiki, I've
added documentation on the currently supported configuration parameters
of Maven plugins that is being read by JDT, AJDT and WTP project
configurators.
Please see the following wiki pages for more details.
http://docs.codehaus.org/display/M2ECLIPSE/Integration+with+ JDT
http://docs.codehaus.org/display/M2ECLIPSE/Integration+with+ AJDT
http://docs.codehaus.org/display/M2ECLIPSE/Integration+with+ WTP
To help us prioritize implementation of other configuration
parameters, please check your projects and open an enhancement requests
in the project jira at http://jira.codehaus.org/browse/MNGECLIPSE
It would help us to save some time if you provide simple test project
that would illustrate usage of given unsupported parameter.
Eugene
Previous Topic:Tycho build 0.3.0-DEV-1785
Next Topic:Using m2eclipse for Eclipse plugin projects
Current Time: Tue Jul 15 00:44:53 EDT 2025
Powered by FUDForum. Page generated in 0.02391 seconds
