Home » Eclipse Projects » Eclipse Platform » display problem in WizardDialog
display problem in WizardDialog [message #19656] Mon, 28 April 2003 11:05 Go to next message
Originally posted by: christian.sell.netcologne.de
I have a TableViewer (org.eclipse.jface.viewers) subclass which I am
displaying in a LaunchConfigurationTab.
Now I am trying to use the same viewer on a WizardPage. This seemed to
work at first - but strangely, the viewer does not display the table
contents when they are changed programatically.
All the code that is executed is the same in both cases. I also tried
calling refresh() with no success. What could I be doing wrong?
thanks,
Christian
Re: display problem in WizardDialog [message #19902 is a reply to message #19656] Mon, 28 April 2003 11:30 Go to previous message
ok, solved it. I had forgotten to call setInput() first.
Christian Sell wrote:
> Hello,
> thanks,
> Christian
Previous Topic:popupMenus folder Problem
Next Topic:FileEditorInput works only on IFile?
Current Time: Fri Jun 06 21:12:18 EDT 2025
Powered by FUDForum. Page generated in 0.02582 seconds
