Home » Archived » DSDP - Mobile Tools for Java (MTJ) » preverify error with float[]
preverify error with float[] [message #19651] Mon, 23 July 2007 11:17
Originally posted by: Mark.Tarlton.motorola.com
I'm seeing a problem with unexpected compiler errors when declaring float
arrays.
Platform: Java 1.6, Eclipse 3.3.0, Sun WTK 2.5, MTJ 0.7
The target device is the Sun "DefaultColorPhone" with CLDC1.1 and MIDP2.0
enabled.
I created the default "Hello_World_MIDP" MIDlet and it compiled and ran
properly.
I then added two floating point declarations and recompiled. The first
declaration of a simple float variable was accepted, but the declaration
of a float array generates an error:
"Errors found in preverification. Build Canceled.
Reason:
org.eclipse.mtj.exception.PreverificationException: Errors found in
preverification. Build Canceled"
It also displays a message to the effect that "floating point not allowed
in method definition for startApp."
The example code is below
package hello_world_midp_package;
import javax.microedition.lcdui.Display;
import javax.microedition.lcdui.Form;
import javax.microedition.lcdui.TextField;
import javax.microedition.midlet.MIDlet;
import javax.microedition.midlet.MIDletStateChangeException;
* hello world MIDP
public class Hello_World_MIDP extends MIDlet {
protected Form form;
protected TextField textField;
* @see MIDlet#startApp()
protected void startApp() throws MIDletStateChangeException {
Display d = Display.getDisplay(this);
d.setCurrent(getForm());
float fVar = 1.0f; // THIS WORKS *****************
float[] fVarArray = new float[4]; // THIS DOESN'T **********
form.append("Hello World!" + fVar);
* @see MIDlet#pauseApp()
protected void pauseApp() {
* @see MIDlet#destroyApp(boolean)
protected void destroyApp(boolean flag) throws MIDletStateChangeException
* Method getForm.
* @return Form
protected Form getForm() {
if (form == null) {
form = new Form("Title");
form.append("Hello World");
return form;
Previous Topic:preverify error with float[]
Next Topic:WSDD Replacement?
Current Time: Tue Jul 15 05:53:33 EDT 2025
Powered by FUDForum. Page generated in 0.28883 seconds
