Home » Language IDEs » AspectJ » AJDT StructureModel
AJDT StructureModel [message #19628] Fri, 25 April 2003 07:01 Go to next message
Originally posted by: stoerzer.infosun.fmi.uni-passau.de
Hi everybody!
Is there some sample code around how to consistently access the
StructurModel of a given AspectJ file?
I tried to figure it out by reading some source and managed to get the
model, but it is empty, so I guess I missed something...
Thanks for help,
Max
Re: AJDT StructureModel [message #19673 is a reply to message #19628] Mon, 28 April 2003 08:02 Go to previous messageGo to next message
AJDT makes use of the AspectJ structure in order to display the contents
of the outline view and for the visualiser.
The FAQ here:
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/org. eclipse.ajdt/faq.html?rev=1.2&content-type=text/html
describes how to access the source for AJDT (see questions 4.2 and 4.3).
In particular, the package org.eclipse.ajdt.internal.core and the class
org.eclipse.ajdt.internal.ui.editor.AspectJContentOutlinePag e show how we
interact with the structure model.
The model itself is defined in the AspectJ project
(http://www.eclipse.org/aspectj) where you'll find the org.aspectj.asm
package.
Adrian.
Re: AJDT StructureModel [message #19968 is a reply to message #19673] Wed, 07 May 2003 07:22 Go to previous message
Hi Adrian!
Thanks for the hints - reading code often helps ;o)
CU
Max
> The FAQ here:
> package.
> Adrian.
Re: AJDT StructureModel [message #565934 is a reply to message #19628] Mon, 28 April 2003 08:02 Go to previous message
The FAQ here:
package.
Adrian.
Re: AJDT StructureModel [message #566164 is a reply to message #19673] Wed, 07 May 2003 07:22 Go to previous message
Hi Adrian!
CU
Max
> The FAQ here:
> package.
> Adrian.
Previous Topic:Problem with Eclipse starting up
Next Topic:developing AJDT with AspectJ
Current Time: Sat Jul 12 19:01:40 EDT 2025
Powered by FUDForum. Page generated in 0.03914 seconds
