Home » Language IDEs » ServerTools (WTP) » JEM: Introducing additional jars to a bean proxy factory classpath
JEM: Introducing additional jars to a bean proxy factory classpath [message #204373] Tue, 13 November 2007 20:52 Go to next message
Is there a way to introduce additional jars to the classpath of the bean
proxy factory? For example, if I do:
ProxyFactoryRegistry registry =
IDERegistration.startAnImplementation(null, false, project,
project.getName(), JSFCorePlugin.PLUGIN_ID, new
NullProgressMonitor());
IStandardBeanTypeProxyFactory factory = registry.getBeanTypeProxyFactory();
Is there a way to inject additional jars into factory's search path that
aren't explicitly in the classpath of project?
The use case I have is that I am trying to introspect tag handler classes
at design time, however I can get linkage (NoClassDefFound) problems
because the tag handler class depends the Servlet API which will only be
on the classpath if the user has designated a default server runtime. In
this case, I'd like the automatically inject the orbit jar(s) that are
needed to get a valid class load.
--Cam
Re: JEM: Introducing additional jars to a bean proxy factory classpath [message #204567 is a reply to message #204373] Fri, 16 November 2007 02:11 Go to previous message
On Tue, 13 Nov 2007 20:52:14 -0500, Cameron Bateman <cameron.bateman@ora=
cle.com> wrote:
> Is there a way to introduce additional jars to the classpath of the be=
an
> ProxyFactoryRegistry registry =3D
> IStandardBeanTypeProxyFactory factory =3D registry.getBeanTypeProxyFac=
tory();
> Is there a way to inject additional jars into factory's search path th=
> The use case I have is that I am trying to introspect tag handler clas=
ses
> because the tag handler class depends the Servlet API which will only =
be
> on the classpath if the user has designated a default server runtime. =
In
> this case, I'd like the automatically inject the orbit jar(s) that are=
> --Cam
I'm not sure about an answer to your original question, but is that the =
only reason
you're using JEM? JEM is effectively deprecated, and should be avoided, =
I believe, unless
you really need it for "Java EMF Models".
I think in JSP land, we define our own simple classloader when we do thi=
ngs like this ...
which may not be that great either :) but it usually pretty easy, using =
the normal eclipse one
as the base, and then there are ways to add jars to that.
Previous Topic:WTP and Websphere 6.1
Next Topic:Eclipse 3.4 M2 and WTP 3.0 M2 Update Manager Issues
Current Time: Sat Jul 26 23:09:17 EDT 2025
Powered by FUDForum. Page generated in 0.05649 seconds
