Home » Archived » EPF » linux/GTK RC1/RC2 fails to start
linux/GTK RC1/RC2 fails to start [message #19621] Sun, 01 October 2006 07:23 Go to next message
Originally posted by: axel.mueller.amit-services.de
eclipse is running on my amd64/opensuse10.1 with 32bit java 1.4.xx without
any problem. but:
Trying to start the eclipse installed with epf-composer, I get a dialogbox
saying:
Eclipse Process Framework Composer cannot be started while another instance
is running. Switch to the running instance or close it and restart the
application again.
Of course, no other instance is running and MOZILLA_FIVE_HOME is set.
Thanks and best regards,
Axel Mueller
Re: linux/GTK RC1/RC2 fails to start [message #19666 is a reply to message #19621] Sun, 01 October 2006 12:37 Go to previous messageGo to next message
Originally posted by: christopher.fuhrman.etsmtl.ca
Axel Müller wrote:
> any problem. but:
> saying:
> application again.
I don't use linux much these days, and I have no idea of how the epf
composer runs, but perhaps it's simply a ".lock" (or similar flag) file
that is present from when composer might have crashed before.
Maybe you can look for such files and try to clean them. It's just a
wild guess - hope nobody minds.
Prof. Christopher Fuhrman
Department of Software and IT Engineering
University of Quebec - École de technologie supérieure (ETS)
http://profs.logti.etsmtl.ca/cfuhrman/index.shtml?en
+1 (514) 396 8638
Re: linux/GTK RC1/RC2 fails to start [message #19758 is a reply to message #19666] Sun, 01 October 2006 14:57 Go to previous messageGo to next message
No, there's nothing like a lock file. I fear it's a OpenSuse/x86_64 or a
OpenSuse/GTK problem. I hope, that the upcoming 1.0 release of EPF comes as
a plugin and installs on my running eclipse (eclipse-SDK-3.2-linux-gtk).
thanks,
Axel Müller
> Axel Müller wrote:
>> without any problem. but:
>> dialogbox saying:
>> instance is running. Switch to the running instance or close it and
>> restart the application again.
axel.mueller@amit-services.de
http://www.amit-services.de
tel +49 +6322 680 668
mobil +49 0160 973 483 27
Re: linux/GTK RC1/RC2 fails to start [message #19836 is a reply to message #19758] Mon, 02 October 2006 16:14 Go to previous messageGo to next message
Originally posted by: storaskar.xx.xxx.xxx
Looks like you have similar case as mentioned here
https://bugs.eclipse.org/bugs/show_bug.cgi?id=157435
Your options are
1) add "-data <workspace_dir>" to the epf command line. It seems some
platforms don't read the -data from the epf.ini correctly.
OR
2) add "-nolock" to the epf command line - this bypasses the locking
check.
Re: linux/GTK RC1/RC2 fails to start [message #19957 is a reply to message #19836] Tue, 03 October 2006 06:33 Go to previous message
Nr. 1) did it!
I searched for a bug, but didn't find this one.
Thank You very much,
Axel Müller
> Your options are
> OR
> check.
> Thanks
Re: linux/GTK RC1/RC2 fails to start [message #566163 is a reply to message #19621] Sun, 01 October 2006 12:37 Go to previous message
Axel Müller wrote:
> any problem. but:
> saying:
> application again.
+1 (514) 396 8638
Re: linux/GTK RC1/RC2 fails to start [message #566236 is a reply to message #19666] Sun, 01 October 2006 14:57 Go to previous message
thanks,
Axel Müller
> Axel Müller wrote:
>> dialogbox saying:
Re: linux/GTK RC1/RC2 fails to start [message #566314 is a reply to message #19758] Mon, 02 October 2006 16:14 Go to previous message
Your options are
OR
check.
Re: linux/GTK RC1/RC2 fails to start [message #566416 is a reply to message #19836] Tue, 03 October 2006 06:33 Go to previous message
Nr. 1) did it!
Axel Müller
> Your options are
> OR
> check.
> Thanks
Previous Topic:"Policy" Guidance category
Next Topic:CMMI plugin?
Current Time: Sat Jul 12 13:56:19 EDT 2025
Powered by FUDForum. Page generated in 0.04956 seconds
