Home » Eclipse Projects » Subversive » Update site problem
Update site problem [message #19620] Fri, 23 May 2008 06:53 Go to next message
There seems to be a problem with the update site. The one at
download.eclipse.org seems to be pointing to
org.eclipse.team.svn - 0.7.0.v20080425
which does not seem to be there
The copy at the UK Mirror service points to
org.eclipse.team.svn - 0.7.0.v20080521
and that does seem to be there.
The UK mirror service URL implies that download.eclipse.org is the
master copy so unless that is fixed the mirror will presumably update
itself to the broken state before too long.
The archived update site for the 20080521 version seems to be OK.
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: Update site problem [message #19764 is a reply to message #19620] Fri, 23 May 2008 11:57 Go to previous message
Hi, Owen.
Maybe there is some problems with some Eclipse Update Manager cache, or
your proxy cache...
Are you using proxy server? Cause we have the same problem sometimes and
clearing proxy cache always helps:).
The other case if you're not using proxy...
I've just tried to install a plug-in from a remote update-side into fresh
Eclipse and Eclipse IDE with Subversive 0.7.0.v20080517 installed - both
gave me a positive result.
Best regards, Alexei Goncharov.
Subversive Team.
Previous Topic:problems connecting to subversion repository using svn+ssh
Next Topic:Instalation problem "requires org.eclipse.team.svn"
Current Time: Thu Jul 10 04:17:36 EDT 2025
Powered by FUDForum. Page generated in 0.27135 seconds
