Home » Eclipse Projects » Mylyn » Using Mylyn from other plug-ins (task picker)
Using Mylyn from other plug-ins (task picker) [message #19618] Thu, 26 July 2007 12:11 Go to next message
Originally posted by: mphippard.collab.net
I have an app I am working on that needs to access data in issues stored in
an issue tracker. I am writing this to Mylyn as that is what our issue
tracker uses for its UI.
I have a select box, where a user can enter a list of tasks. I have my code
working to properly get the task data using Mylyn. This was easy to do, by
the way. The API was great.
The only thing I'd like to do that I haven't is provide some kind of select
dialog that let them select tasks from a list. This dialog could work like
the Open Task dialog does, except I'd want to limit the tasks shown to those
from a specific repository. I'd also like the user to be able to specify
multiples.
So two questions:
1) Do you provide any Select Dialog like this that can be used?
2) I cannot find the API one would use to build this. I basically just want
something that can list all of the tasks that are known locally for a
repository.
Mark
Re: Using Mylyn from other plug-ins (task picker) [message #19663 is a reply to message #19618] Thu, 26 July 2007 12:27 Go to previous messageGo to next message
On 7/26/07 12:11 PM, in article C2CE3FFA.4BB1%mphippard@collab.net, "Mark
> multiples.
> So two questions:
> repository.
I found TaskListManager after sending this. So I know I can do #2 easily
enough.
Mark
Re: Using Mylyn from other plug-ins (task picker) [message #19708 is a reply to message #19663] Thu, 26 July 2007 12:43 Go to previous messageGo to next message
>>multiples.
>>So two questions:
>>repository.
> enough.
> Mark
If you can query a list of tasks, then you can make a selection dialog
sort of like this:
* ListSelectionDialog dlg =
* new ListSelectionDialog(
* getShell(),
* input,
* new BaseWorkbenchContentProvider(),
* new WorkbenchLabelProvider(),
* "Select the resources to save:");
* dlg.setInitialSelections(dirtyEditors);
* dlg.setTitle("Save Resources");
* dlg.open();
You would just need content and label providers that work with tasks.
HTH,
David
Re: Using Mylyn from other plug-ins (task picker) [message #19789 is a reply to message #19708] Thu, 26 July 2007 13:45 Go to previous messageGo to next message
On 7/26/07 12:43 PM, in article f8aiv0$umt$1@build.eclipse.org, "David
>>> multiples.
>>> So two questions:
>>> repository.
>> enough.
>> Mark
> sort of like this:
> * getShell(),
> * input,
> * dlg.open();
Thanks. Building our own dialog is not an issue, as we are experienced
Eclipse team. I just wanted to know if there was something to reuse, and if
not, what the data API was. I had looked for the latter and not found it
until I sent it.
Mark-
Re: Using Mylyn from other plug-ins (task picker) [message #19939 is a reply to message #19789] Fri, 27 July 2007 10:35 Go to previous messageGo to next message
>>>> multiples.
>>>> So two questions:
>>>> repository.
>>> enough.
>>> Mark
>> sort of like this:
>> * getShell(),
>> * input,
>> * dlg.open();
> until I sent it.
> Mark-
There currently isn't a dialog that meets these requirements although
Willian Mitsuda contributed the RemoteTaskSelectionDialog
(OpenRepositoryTask) dialog and is likely the best place to start from.
That and the TaskSelectionDialog.
-Rob
Re: Using Mylyn from other plug-ins (task picker) [message #19984 is a reply to message #19939] Fri, 27 July 2007 21:47 Go to previous message
Originally posted by: beatmik.acm.org
Mark: this sounds like a very reasonable enhancement request for the API
to support (e.g. a repository-specific way of invoking the Open Task
dialog). I can imagine other connectors wanting this, and a you'll
notice from bugs like the following that the UI parts of this can be
tricky and could be good to make commonly available.
193849: [patch] Allow filtering of completed tasks open task dialog
https://bugs.eclipse.org/bugs/show_bug.cgi?id=193849
That said, experimenting with your own dialog could still be a good
idea, in particular if you are able to couple to the new
FilteredItemsSelectionDialog API in Eclipse 3.3.
Just fyi, this kind inquiry is best sent to the mylyn-integrators
mailing list.
Mik
> -Rob
Re: Using Mylyn from other plug-ins (task picker) [message #575716 is a reply to message #19618] Thu, 26 July 2007 12:27 Go to previous message
> multiples.
> So two questions:
> repository.
enough.
Mark
Re: Using Mylyn from other plug-ins (task picker) [message #575783 is a reply to message #19663] Thu, 26 July 2007 12:43 Go to previous message
>>multiples.
>>So two questions:
>>repository.
> enough.
> Mark
sort of like this:
* getShell(),
* input,
* dlg.open();
HTH,
David
Re: Using Mylyn from other plug-ins (task picker) [message #575858 is a reply to message #19708] Thu, 26 July 2007 13:45 Go to previous message
>>> multiples.
>>> So two questions:
>>> repository.
>> enough.
>> Mark
> sort of like this:
> * getShell(),
> * input,
> * dlg.open();
until I sent it.
Mark-
Re: Using Mylyn from other plug-ins (task picker) [message #575928 is a reply to message #19789] Fri, 27 July 2007 10:35 Go to previous message
>>>> multiples.
>>>> So two questions:
>>>> repository.
>>> enough.
>>> Mark
>> sort of like this:
>> * getShell(),
>> * input,
>> * dlg.open();
> until I sent it.
> Mark-
-Rob
Re: Using Mylyn from other plug-ins (task picker) [message #575951 is a reply to message #19939] Fri, 27 July 2007 21:47 Go to previous message
mailing list.
Mik
> -Rob
Previous Topic:Bugzilla not providing well-formed document
Next Topic:Custom Resolution values in Bugzilla not shown in Mylyn
Current Time: Mon Jul 07 13:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.14166 seconds
