Home » Language IDEs » Java Development Tools (JDT) » M7 ANT mail-tag hangs
M7 ANT mail-tag hangs [message #204253] Thu, 19 May 2005 11:22 Go to next message
Originally posted by: no-spam-Marc.Dzaebel.gaia-group.com
After migration to M7 (from M6) my mail-tag simply stops without a
message. I tried different mail.jar / activation.jar but nothing
changed. Is this a known bug?
Thanks in advance
Marc
Re: M7 ANT mail-tag hangs [message #204269 is a reply to message #204253] Thu, 19 May 2005 11:48 Go to previous messageGo to next message
If the build starts and then hangs this is not a known bug.
Between M6 and M7 we did upgrade to Ant 1.6.3 so that is one possibility.
I would see if you buildfile works from the commandline with Ant 1.6.3. If
not then it is an Ant bug.
If it does then it is an Eclipse integration bug...which I would greatly
appreciate hearing further about in a bug report.
Darins
"Marc Dzaebel" <no-spam-Marc.Dzaebel@gaia-group.com> wrote in message
news:d6iasl$4lh$1@news.eclipse.org...
> Thanks in advance
> Marc
Re: M7 ANT mail-tag hangs [message #204372 is a reply to message #204269] Fri, 20 May 2005 06:24 Go to previous messageGo to next message
It starts and shows no error message. Where else can I look for it?
I upgraded to M7 on an other XP-machine and there it works! So it seems
to be a configuration problem on my Win2000 system.
So currently no bug report is necessary. I'll keep you up to date.
Thanks for your very quick response on this topic!
Marc
Re: M7 ANT mail-tag hangs [message #204411 is a reply to message #204372] Fri, 20 May 2005 12:41 Go to previous messageGo to next message
Can you provide a sample, simple buildfile that I can test with? No matter
who's bug it is things should not hang :-)
The only bug that is similar and could explain the differences between the 2
machines
https://bugs.eclipse.org/bugs/show_bug.cgi?id=95611
HTH
Darins
news:d6kdq6$929$1@news.eclipse.org...
>> If
> I upgraded to M7 on an other XP-machine and there it works! So it seems to
> Marc
Re: M7 ANT mail-tag hangs [message #204419 is a reply to message #204411] Fri, 20 May 2005 12:05 Go to previous messageGo to next message
e.g. a simple <mail from="any" tolist="any"/>
leads to hang after the message Sending email: null. However, you might
not be able to reproduce the problem because it seems to be a
misconfiguration of my system. E.g. mail.jar & activation.jar have to be
added to ANT_HOME/lib.
> machines
But I don't get any error message after "Sending email:" which excludes
this problem?
> HTH
> Darins
>>>If
>>Marc
Re: M7 ANT mail-tag hangs [message #204425 is a reply to message #204419] Fri, 20 May 2005 13:09 Go to previous messageGo to next message
Ok...then this is looking like an Ant bug that they hang if the required
JARs are not available (mail.jar and activation.jar).
Darins
news:d6l1rd$38g$1@news.eclipse.org...
>> matter who's bug it is things should not hang :-)
>> the 2 machines
> this problem?
>> HTH
>> Darins
>>>>possibility.
>>>>If
>>>Marc
Re: M7 ANT mail-tag hangs [message #210296 is a reply to message #204425] Wed, 20 July 2005 10:14 Go to previous messageGo to next message
Finally, I discovered, that the mail-tag hangs only if I call
<java jar="name.jar" fork="yes" />
in advance. (fork="yes" is required to execute a jar)
This bug was very hard to find!
Any help is welcome!
Thanks, Marc
> Thanks
> Darins
>>>the 2 machines
>>this problem?
>>>HTH
>>>Darins
>>>>>possibility.
>>>>>If
>>>>Marc
Re: M7 ANT mail-tag hangs [message #210322 is a reply to message #210296] Wed, 20 July 2005 11:26 Go to previous messageGo to next message
Does the same build work outside of Eclipse at the commandline?
If not then this would be an issue you should take up with the Apache Ant
user mailing list or Apache Ant bug reporting.
If it works at the commandline and not in Eclipse, then please log a bug
report in Eclipse bugzilla and I will get to the bottom of the problem
Darins
news:42DE5C51.5090000@gaia-group.com...
> Thanks, Marc
>> Thanks
>> Darins
>>>>the 2 machines
>>>this problem?
>>>>HTH
>>>>Darins
>>>>>>possibility.
>>>>>>1.6.3. If
>>>>>>greatly
>>>>>Marc
Re: M7 ANT mail-tag hangs [message #210467 is a reply to message #210322] Thu, 21 July 2005 07:17 Go to previous message
Note that the same build.xml works outside Eclipse with ANT 1.6.5 ! So I
reported the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104634
The bug remains in the recent Eclipse 3.1
Marc
> Thanks
> Darins
>>Thanks, Marc
>>>Thanks
>>>Darins
>>>>>the 2 machines
>>>>this problem?
>>>>>HTH
>>>>>Darins
>>>>>>>possibility.
>>>>>>>1.6.3. If
>>>>>>>greatly
>>>>>>Marc
Previous Topic:The selected stack frame must be associated with a Java project in the workspace
Next Topic:default Java builder in eclipse
Current Time: Fri Jul 25 22:04:40 EDT 2025
Powered by FUDForum. Page generated in 1.06330 seconds
