Home » Eclipse Projects » GEF » L&F : Focus Rectangle
L&F : Focus Rectangle [message #203801] Mon, 28 November 2005 07:01 Go to next message
Originally posted by: awm_abu.yahoo.com
Hello all,
I have had a request from the Look and Feel people here to change the look
of the focus rectangle that appears when you select a Figure.
At the moment it appears as 8 small black rectangles around the edge of the
rectangle area connected with lines.
When you try to move the Figure the rectangle changes to a series of dots.
The L&F people would prefer the focus rectangle to look like the latter one
mentioned - a series of dots.
How do I go about changing this ?
Regards.
Re: Focus Rectangle [message #203826 is a reply to message #203801] Mon, 28 November 2005 10:08 Go to previous messageGo to next message
Originally posted by: none.unknown.com
That's the selection rectangle, not the focus rectangle. To see the focus
rectangle, use Ctrl + Arrow keys.
"Frank Abercorn" <awm_abu@yahoo.com> wrote in message
news:dmerj6$fkd$1@news.eclipse.org...
> Hello all,
the
one
> Regards.
Re: Focus Rectangle [message #203834 is a reply to message #203826] Mon, 28 November 2005 10:16 Go to previous messageGo to next message
Thanks Pratik,
You are correct I was referring to the Selection rectangle.
I have checked with them and they also want this changed.
So is there a way to change the rectangle to a series of dots similar to the
focus rectangle ?
Thanks again.
"Pratik Shah" <none@unknown.com> wrote in message
news:dmf6hq$44r$1@news.eclipse.org...
>> Hello all,
>> look
> the
>> dots.
> one
>> Regards.
Re: Focus Rectangle [message #203948 is a reply to message #203834] Tue, 29 November 2005 05:40 Go to previous message
Hi!
> focus rectangle ?
That's possible. You need to overwrite the layout EditPolicy of the
parent container to return a custom EditPolicy for the children that
should have their selection changed.
For the container LayoutEditPolicy see:
org.eclipse.gef.editpolicies.LayoutEditPolicy#createChildEdi tPolicy(EditPart)
For the custom child EditPolicy returned there see:
org.eclipse.gef.editpolicies.SelectionHandlesEditPolicy#crea teSelectionHandles()
I'm not sure if there are some examples in the Logic example.
Cu, Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Previous Topic:how to move an anchor by user
Next Topic:Displaying Editor
Current Time: Thu Nov 27 22:16:10 EST 2025
Powered by FUDForum. Page generated in 0.04107 seconds
