Home » Language IDEs » Java Development Tools (JDT) » Can't debug source code in M7
Can't debug source code in M7 [message #203722] Tue, 17 May 2005 09:19 Go to next message
Hello
I have moved from M6 to M7 and I find I cannot make the debugger go to the
source code when it stops at a breakpoint.
I create a project called foo with the following (nothing else) class in the
directory "src" at the root of the project:
public class MainFoo
public static void main(String[] args)
int i = 8;
i++;
There is a breakpoint at the i++ statement. The breakpoint is hit and I get
a white editor with "Source not found" and a button labelled "Edit Source
Lookup Path"
When I click the button I find the Source Lookup path contains a "Default"
root which contains "foo", which contains "src - \foo"
I appreciate any suggestions.
I am on Windows, Java 1.5
Michael
Re: Can't debug source code in M7 [message #203749 is a reply to message #203722] Tue, 17 May 2005 10:34 Go to previous messageGo to next message
Anything in the log?
Darin
"Michael Doorley" <michael.doorley@eeng.dcu.ie> wrote in message
news:d6cr4v$qs4$1@news.eclipse.org...
> Hello
> the directory "src" at the root of the project:
> int i = 8;
> i++;
> get a white editor with "Source not found" and a button labelled "Edit
> Source Lookup Path"
> Michael
Re: Can't debug source code in M7 [message #203778 is a reply to message #203749] Tue, 17 May 2005 10:51 Go to previous messageGo to next message
I'm not sure where i should be looking for the log. There's no .log file in
workspace\.metadata
"Darin Wright" <Darin_Wright@ca.ibm.com> wrote in message
news:d6cvij$1v6$1@news.eclipse.org...
> Darin
>> Hello
>> the source code when it stops at a breakpoint.
>> int i = 8;
>> i++;
>> Source Lookup Path"
>> "Default" root which contains "foo", which contains "src - \foo"
>> Michael
Re: Can't debug source code in M7 [message #203785 is a reply to message #203778] Tue, 17 May 2005 11:20 Go to previous messageGo to next message
I have exactly the same problem ..
M6 was working fine and using the M7 i have the "Source not found"
I tried to rebuild my projects , start with a -clean , .... nothing was
working ....
In the log there is the following messages :
!SUBENTRY 1 org.eclipse.debug.core 4 120 2005-05-16 10:37:00.790
!MESSAGE Unable to access archive D:\DEV\2.1\tools\lib
!STACK 0
java.util.zip.ZipException: Access is denied
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
org.eclipse.debug.internal.core.sourcelookup.SourceLookupUti ls.getZipFile(SourceLookupUtils.java:67)
org.eclipse.debug.core.sourcelookup.containers.ExternalArchi veSourceContainer.getArchive(ExternalArchiveSourceContainer. java:193)
org.eclipse.debug.core.sourcelookup.containers.ExternalArchi veSourceContainer.findSourceElements(ExternalArchiveSourceCo ntainer.java:79)
org.eclipse.debug.core.sourcelookup.containers.CompositeSour ceContainer.findSourceElements(CompositeSourceContainer.java :78)
org.eclipse.debug.core.sourcelookup.containers.CompositeSour ceContainer.findSourceElements(CompositeSourceContainer.java :45)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupPart icipant.findSourceElements(AbstractSourceLookupParticipant.j ava:60)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor$SourceLookupQuery.run(AbstractSourceLookupDirector.java :126)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1029)
at org.eclipse.core.runtime.Platform.run(Platform.java:775)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.doSourceLookup(AbstractSourceLookupDirector.java:465)
org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.getSourceElement(AbstractSourceLookupDirector.java:715)
org.eclipse.debug.internal.ui.sourcelookup.SourceLookupFacil ity.lookup(SourceLookupFacility.java:138)
at org.eclipse.debug.ui.DebugUITools.lookupSource(DebugUITools. java:658)
org.eclipse.debug.internal.ui.views.launch.LaunchView$Source LookupJob.run(LaunchView.java:176)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:67)
news:d6d0i5$3ar$1@news.eclipse.org...
> Hi
> in workspace\.metadata
>> Darin
>>> Hello
>>> int i = 8;
>>> i++;
>>> Source Lookup Path"
>>> Michael
Re: Can't debug source code in M7 [message #203800 is a reply to message #203785] Tue, 17 May 2005 11:52 Go to previous messageGo to next message
Do you get the same problem even with a simple 2 line program like my "foo"
project?
Michael
"T.Hanot" <thanot@infovista.com> wrote in message
news:d6d24m$5li$1@news.eclipse.org...
> working ....
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Hi
>>> Darin
>>>> Hello
>>>> in the directory "src" at the root of the project:
>>>> int i = 8;
>>>> i++;
>>>> I get a white editor with "Source not found" and a button labelled
>>>> "Edit Source Lookup Path"
>>>> Michael
Re: Can't debug source code in M7 [message #203832 is a reply to message #203800] Tue, 17 May 2005 12:42 Go to previous messageGo to next message
Yes the same...
I 'm not sure about this
but may be it's the way we are starting eclipse :
using the -data <MYWORKSPACE> it 's not working
specifying the workspace with the eclipse dialog box , allow it to works ...
i don't understand exactly why ...
May be because the -data does not support the Windows syntax using a
different drive ( d: )
news:d6d43j$8a5$1@news.eclipse.org...
> Hi
> "foo" project?
> Michael
>> working ....
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Hi
>>> file in workspace\.metadata
>>>> Darin
>>>>> Hello
>>>>> int i = 8;
>>>>> i++;
>>>>> Michael
Re: Can't debug source code in M7 [message #203870 is a reply to message #203832] Tue, 17 May 2005 13:51 Go to previous messageGo to next message
specifying the workspace with the eclipse dialog box does not work for me
My workspace is outside the Eclipse directory structure, i.e. I have
C:\eclipse
C:\workspace
Maybe that is relevant. Maybe the debugger needs to be told if the source
is outside the Eclipse root.
I have tried many things. I notice that if I add the directory of the
source code using the Source Tab on the Debug dialog (as a File System
Directory), then the debugger picks up the location. However it is a read
only version of the file. It is missing a lot of the functionality I am
used to.
The problem was also reported in the Eclipse Platform newsgroup.
news:d6d6tt$c1a$1@news.eclipse.org...
> Yes the same...
>> Hi
>> "foo" project?
>> Michael
>>> working ....
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>>> Hi
>>>>> Darin
>>>>>> Hello
>>>>>> to the source code when it stops at a breakpoint.
>>>>>> int i = 8;
>>>>>> i++;
>>>>>> and I get a white editor with "Source not found" and a button
>>>>>> labelled "Edit Source Lookup Path"
>>>>>> Michael
Re: Can't debug source code in M7 [message #203985 is a reply to message #203870] Wed, 18 May 2005 04:22 Go to previous messageGo to next message
I restored a backup of the workspace (The workspace I used with M6).
Debugging is now behaving properly. My directory structure is not a
problem. i.e. the following works:
> C:\eclipse
> C:\workspace
news:d6db32$h75$1@news.eclipse.org...
> C:\eclipse
> C:\workspace
> source is outside the Eclipse root.
> used to.
>> Yes the same...
>>> Hi
>>> "foo" project?
>>> Michael
>>>> working ....
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>>> Hi
>>>>>> Darin
>>>>>>> Hello
>>>>>>> class in the directory "src" at the root of the project:
>>>>>>> int i = 8;
>>>>>>> i++;
>>>>>>> Michael
Re: Can't debug source code in M7 [message #204079 is a reply to message #203722] Wed, 18 May 2005 12:17 Go to previous message
Likely https://bugs.eclipse.org/bugs/show_bug.cgi?id=95679
Darins
> Hello
the
> int i = 8;
> i++;
get
> Lookup Path"
> Michael
Previous Topic:JDK 5.0 on OS X 10.4
Next Topic:3.1 M7: Ant External Tools do not work when running on a separate JRE
Current Time: Mon Jul 21 22:07:01 EDT 2025
Powered by FUDForum. Page generated in 0.10227 seconds
