| build settings environment not saving [message #203714] |
Fri, 26 October 2007 20:59  |
Originally posted by: jim.marshall.wbemsolutions.com
I hope I didn't miss a FAQ, sorry if I did.
Short story, I go to properties, select C/C++ Build and choose
'environment' and create a new variable. If I then exit eclipse and
restart eclipse, that variable is gone.... I would like the variable to
remain between invocations (and even get saved into the CVS version of
the project).
I have an existing make system which I have loaded into Eclipse CDT.
This make system uses some command line vars to make or environment vars
to inform the make system of the type of build to do. I created a new
project (file->New Project->C Project, I selected Makefile Project) and
pointed it at my top level directory. I then edited the configuration
(project->Build Configurations->manage...). I renamed the default one to
"Windows Debug" and created a new one called "Windows Release". I exited
that dialog, then select Project->Properties. I click on the C/C++
build, then select "Environment" option. In the dialog I create two new
variables "DEBUG_BUILD=1" and "PLATFORM=WIN32_GNU_GCC". Now if I exit
Eclipse and restart it both of those variables are gone.
Is there a way to maintain environment variables for different
configurations?
Essentially I need 2 configurations for each platform we support which
needs these vars set.
Eclipse
Version: 3.3.0
Build id: M20070921-1145
CDT
4.0.1.200709241202
| Re: build settings environment not saving [message #203752 is a reply to message #203714] |
Sun, 28 October 2007 11:52   |
Originally posted by: vbagga.versant.com
Hi Jim,
This is known bug (https://bugs.eclipse.org/bugs/show_bug.cgi?id=205460)
that has been fixed. It was working with CDT 4.0.0.
... But unfortunately no one seems to have responded to my query about
how to get the nightly build (For 4.0.2) that would include this fix.
So you could either:
1) Wait till someone responds (might not happen at all)
2) Go back to CDT 4.0.0.
3) Try applying the patch yourself, I guess you would need to build the
CDT for that.
- Vishal
Jim Marshall wrote, On 10/27/2007 2:59 AM:
> the project).
> configurations?
> Eclipse
> Version: 3.3.0
> CDT
> 4.0.1.200709241202
> Thanks
| Re: build settings environment not saving [message #203772 is a reply to message #203752] |
Mon, 29 October 2007 01:13  |
Originally posted by: ronbermejo.yahoo.com
Vishal Bagga wrote:
> Hi Jim,
> CDT for that.
> - Vishal
Hi Vishal, Jim.
There's another option with CDT 4.0.1 which is a bit of a hack but works
if you cannot do options 1) to 3) above:
1. Open the ".cproject" file in a text or XML editor
2. Look for the <storageModule> element whose "name" attribute is equal to
the configuration you want the environment variables for. (e.g., for
"Debug" configuration)
<storageModule
buildSystemId=" org.eclipse.cdt.managedbuilder.core.configurationDataProvide r "
id="cdt.managedbuild.config.gnu.mingw.exe.debug.942367524"
moduleId="org.eclipse.cdt.core.settings" name="Debug">
3. Insert an <environment> element similar to the one below. Add
<variable> elements inside corresponding to each environment variable you
want to configure. Set the "name" and "value" attributes appropriately.
(e.g. this sets MYENVIRONMENTVARIABLE=abcdef)
<environment append="true" appendContributed="true">
<variable delimiter=";" name="MYENVIRONMENTVARIABLE" operation="append"
value="abcdef"/>
</environment>
4. Open the project in Eclipse. It should now be available. However, any
changes you make in the UI will not be persisted.
Hope this helps!
Ron
FUDForum. Page generated in 0.02603 seconds
